R34 GTR the same?
The ratios are different but they will all do those kinds of speeds if the power, strength of drivetrain and wind resistance is all living in 'the perfect world'.
Obviously there are restrictions and this is based on the estimate of ~3000rpm in 5th at 100km/h and every 250rpm higher is ~10km/h faster.
The easiest way to tell is to do 100km/h, note the revs, then go up 250 or 500rpm and use this to calculate your top speed at redline.
Keeping in mind that it will require approx 450hp at the wheels to go around 200mph and another 100hp at the wheels to go another 20mph. This is approximate also as relayed to me by a mate of mine who races on salt lakes.
https://www.sau.com.au/forums/topic/255085-gtr-topspeed/#findComment-4401169
just trying to figure out (i have no idea if im right) but say you made 7000rpm the limit, would not all the cars of that model have the exact same top speed because of the final drive/diff ratio?
if in theory you could reach it power wise????????
https://www.sau.com.au/forums/topic/255085-gtr-topspeed/#findComment-4401163
They do not all have the same gear ratios.
There are different things that will effect the top speed: Gearset ratios, diff ratios, tyre size, top rpm, and finally the car's wind resistance.
But yeah, if you have 2 R32GTR's exactly the same, they would do the same speed at 7k
https://www.sau.com.au/forums/topic/255085-gtr-topspeed/#findComment-4401176
hey thanks for that :D
robbie
https://www.sau.com.au/forums/topic/255085-gtr-topspeed/#findComment-4401175
