hey guys.
friday night i had my car smashed into whilst parked on the road out front of my house.thay did the runner which is the worst in the world considering i just had the whole can touched up at just over 2g, also layed up and home after surgery so i can bearly move.
anyways im hoping that people can help me as it now needs a few things to get/have it drivable.
r32 front bar type m.
r32 r/hand side gtr head light.
r32 r/hand indicator orange.
i will also be hunting for a bonnet gtr if possible and a right hand guard is they all got f@#ked up by who ever the nice person was!!
please any help would be appreciated
thanks jordan
https://www.sau.com.au/forums/topic/255098-please-help/
Hey jordan my name is musty. i know what your goin through bro i just imported a 32 gtr
it came with a blown motor and the chassis is twisted so i cant register it.
im selling the whole thing in partsand have a gtr bonnet. I want 750 for it. i also have the front guards but i wont seperate there white in colour.
If you want them just call me on 0433-554-014 as i dont really jump on the net.
https://www.sau.com.au/forums/topic/255098-please-help/#findComment-4412524
    • Yes, but it's not as easy as pulling a fuse on anything other than an R32. There's a routine you have to do, involving disconnecting a loom plug and bleeding down the preload.
    • A question for tuning awd, is it possible to disable the AWD? The stagea is an EA/T AWD, Toshi had said on a GTR, he was able to disable it and make it 2wd. Just wanted to double check if this was possible
    • Whoa, that's a name I've not see for a long time! Sorry to hear about the engine / turbo damage.  Fwiw with any engine problems it often really a case of just seeing what happens when it's apart, ymmv - I wouldn't rule out the possibility that the damage isn't even from the turbo failure, or possibly from a combination.  The airflow between cylinders isn't dead even, injectors can go off over time as well, with the turbos overboosting if you didn't have upgraded fuel system there could have possibly been a bit of leaning out - stock triggering is often a bit unreliable by this age too.  Basically its an old engine and a few things could have been going on, and you won't know how much work is needed until the engine is apart.
    • I'm just shocked there's a euro driver on our roads who is thinking of other road users and not attempting to blind everyone. I wonder if Prank uses his indicator too...
    • Its hard to tell really. The Q50 owner's forum talks about it a lot and has quite a few people directly affected, but no idea what % of cars sold actually had the block replaced. Also, there seem to be 2 distinct issues which both get diagnosed by Infiniti as requiring a block replacement (no wonder they are going broke) 1. "Porous block" where coolant mixes with oil through thin or poorly cast parts of the block 2. Head coolant gallery plugs not sealing. If I was noticing engine coolant loss I'd start with cooling system pressure test (as always) and then I'd pull the cam covers and reseal the coolant gallery plugs on both side before worrying about a potentially porous block.  If neither of those did the trick it would be put in a second hand engine out of japan; I haven't checked pricing but I'm sure there are plenty around by now as they've been in production 10+ years
