1997 model series body shell, complianced, immac body & paint .. shell will be bare with windows, may chuck in other bits and pieces .. great project car or for parts.. looking for offers around $1000 - $1500
r34 gtst rims, painted up in silver prismatec .. has falken tyres, rear are pretty bald like 30% left,, front are still good with 70-80% tread
after $650 ono
35/40r turbo, internal waste gate, brand new still have box, paid $2200, after $1500ono
do have more pics and more parts.
located in wollongong 1 hr south of sydney, best point of contact is via sms or phone call on 0402559887
cheers
https://www.sau.com.au/forums/topic/255099-r33-series-2-skyline-with-photos/
front bar sold
i have to get this car out of the garage asap .....
selling all my parts cheap ,,,
still have
series 2 crash pad with passenger air bag and steering wheel with airbag
r/h front guard
rear bar
interior
power steering rack
hubs, rotors, calipers
apexi exhaust system
S2 bonnet
door trims
l/h side door
mirrors
bootlid and spoiler
S2 AFM
dump pipe
lots of bits and pieces
sms or call 0402559887
    • No need to replace the cover if it is still intact (not worn through). It would be worth checking the balancer for matching marks on the rear, but I'd assume the balancer was loose at some stage. The cam timing marks look fine, once you put the new belt on you can only be right or a full tooth out
    • Disconnecting rods! must have been an unpleasant surprise...
    • So been ocd with timing mark but checked from few angle and seems both cam are on and crank is matching as well to the slot on sump and crank pully   i noticed crankshaft cover has been robbed as per attached pic. Any ideas why? Could my balancer or harmonic be on its way out? should I replace the cover? https://ibb.co/ZR1JFYRR
    • So now doing the change and first time dealing with rb so little nervous giving engine power and potential for screwing it up When you align all marks and then remove crank bolt, timing move little I assume you can put the bolt back in once you have removed the pully to get timing to where you want?   here is pic of my both intake and exchust cam aligned, depending on angle you look they seem to be either aligned or a half tooth or so out. Any thoughts? Should you angle your face and look at each mark that way as if looking straight rather than from above as it can be misleading   <a href="https://ibb.co/ZpnhcvbF"><img src="https://i.ibb.co/HfWrGR9b/IMG-4447.jpg" alt="IMG-4447" border="0"></a> <a href="https://ibb.co/4wm2wn4q"><img src="https://i.ibb.co/JWBqWwr1/IMG-4445.jpg" alt="IMG-4445" border="0"></a>   https://ibb.co/ZpnhcvbF https://ibb.co/4wm2wn4q
    • Thanks for the reply @GTSBoy Haven't really thought of that yet, but you are right. If the hose was damaged it should be absolutely pissing by now. I'll put some heat sleeve around it for good measure since I'm already removing the line anyway.  Maybe I'll put on some of the stock hardlines if I ever fully remove the turbos again. Maybe when T51R modding the compressor housings? Might be a fun mod on GT28s for that "fake single turbo" effect.
