I believe the owner of this one is on here somewhere.
he had three requests:
keep the cargo cover so his dog could ride back there
the seats had to fold flat so he could haul things
it had to sound good.
the rest is open slather as long as I stayed within a budget
timewise it was not a concern as its a weekend toy.
this is also my Cruise control mule.
the Victim:
I was presented with this:
told this had to stay:
First Layout idea:
this one didn't work as I hadn't taken into account the cross brace directly behind the seat.
the teardown begins:
Stock stuff:
there is a cruise switch on the right side of that wheel now. (no image.)
new mounts for the speakers. suggest doing this as it seals the speaker to the door panel when done correctly
Stock speaker/tweeter- front drivers door
rear doors JL audio on new mounts
Edited by Chris Rogers
https://www.sau.com.au/forums/topic/255109-m35-stereo-lots-of-piccies/
front drivers door with new JL Audio gear in place
rear end stripped down and speaker wiring run
AV feed to the JVC radio- this will make sense in a minute.
cabling runs.
2nd shot
power cabling
this was a BITCH to do. everything in the path of that harness had to come out
that is the ENTIRE corner where the battery is located. 4AWG cable used.
finished product. all resealed and covered. there is a 100A circuit breaker in there as well
testing things. final locations have been decided well before this.
final concept
JVC radio with DVD video patched back into the OE system.
USB slot :D the ETC unit has been moved under the dash. this needs a bit of a cleanup still
final fit and testing
Rear floor duplication: it still works as its supposed to.
this is the Final layout.
most of this is sitting one things currently for this pic. the sub is mounted UNDER the floor in a removeable
box that fits neatly in the spare wheel. the whole thing comes out so you can get at the
spare tyre. tools are built into the box with a carpet damper so they do not rattle.
(no images yet.)
The amplifers are under 13mm plexiglass and they have two white neon lights that are on a switch to light them up.
time so far 3 weeks on and off between jobs.
Chris, can you buy those MDF speaker mounts from a shop, or even you directly? I don't do wood. If I can't weld it, I don't touch it! :D
for M/V35 - yes. for a C34 - no. yours are different. I make these - they cannot be bought to my knowledge.
ahhh cool as (excuse the pun)
it also reminds me of this install a little http://www.gotou.info/UsersCar/Users_Car/users_stagea.html
:blush:
Damn! Thats a fairly large amount of effort involved!
who do you recommend in Victoria?
i wasn't a fan of the work done by performance car audio, the 'sales' guy at stylin didn't have the greatest attitude... and with a new car coming most likely late this year, need a new installer.
or time for a road trip LOL
-Ryan
if it was a balding older fellow that you talked to at boronia then you met adam. he's pretty to the point when it comes to things. go see him again and mention me :blush:
road trip - yep. I need to sink my teeth into a C34. I do too many M/V35s currently..
more images in a bit. got more done on it today.
floor with holes and plexi panels in place
underside. there is black mesh in the rear slots. I'm doing a test fit on this checking things and reseating
6 blind nuts that I had to pull out to flush the mesh into place
this is the retaining catch that holds these things shut when the struts are in good condition
I have yet to put the retaining straps (at rear) in place.
Nice work, Chris! I'm currently thinking about upgrading my stereo properly (with a single-DIN DVD player, some Dynamat or similar, some amps and a subwoofer, and will replace my Boston speakers if they need it)
I'd like to stick to an Alpine head unit, but am pretty open to what amps and speakers to use, but focussing on SQ for my own personal enjoyment. Can you recommend anyone in Sydney? If I can get it all done in one place, that would be preferred.
