Fitting the std 33 turbo will be cheaper, high flowing your 20 turbo will cost lots, i called turbo tech a while back when i screwed my turbo and they wanted a kidney.... at least....
As far as performance, most people get at least 250 hp at the rears on a std 33 turbo as long as you have some for of fuel controlling device ie SAFC or something... as for high flowed 20 you would probably have to dig about for the results.
Reliability, the 33 turbo is still standard and can (im not saying they all do) shart a rear turbine wheel off... The high flow would be steel wheels and capable of longer life and higher boost. std 33 turbos dont really like 15 pounds of boobs. I do.
Ive personally gone from a std 20 turbo, to a std 33 turbo and now a high flowed 33 turbo, the high flow 33 turbo is un-goddam-believeable, the power up the top end is awesome, but at the same time ,smooth.
At a guess i'd say the high flowed 20 would be better for midrange?
Hope this helps.
Good luck with it all.
Be prepared to have a few bolts snap, or gasket replacement, or, and this is my personal favourite, "you have snapped manifold bolts, 4 to be precise".... or generally some form of pain in the ass. 32's are known for the "EXTRA WORK NEEDED" line from your mechanic.... *looks at my wallet* >_<
Still there is nothing quite like it when all of a sudden at 3500 rpm it pushes you back into the seat.
ENJOY!
33 turbo for cheap horsepower (get a series 1 item, mine has been going hard on my RB20 and now RB30). ~250rwhp out of an untuned RB20, just make sure you have a new fuel pump as the old stocker probably won't keep up.
VG30 turbo is the same size as an RB25 Neo turbo.
I have a neo hiflow on my Stag, it's stupidly large, takes ages to spool but makes 320awhp @ 12psi.
Nissan went with the nylon wheel to get it to spool faster. I really don't think they had people running them at 12-14psi in mind.
Ask around and see how many people have blown series2 turbo's when winding a bit of boost into them.. my series1 turbo has been running 12psi on my RB20 for over a year and now on my RB30 for 1.5years, still going strong.
I have seen countless topics on max boost for the rb25 turbo, to be honest i havent notcied any larger number in s2 failures then s1 but that doesnt mean your not wrong. I have seen lots of results comparing 10psi to 14psi and the max power figure didnt change, however the midrange was improved on the higher psi runs. So then in theory if the S2 turbo spools up quicker as you say, then that would be an improvement in the midrange without needing to up the boost anyways. But thats just my opinion at the end of the day i cant say for sure but thats just what i reckon. Sauwa wouldnt be the same if i didnt get to disagree with you Bubba. :(
HOW DARE YOU DISAGREE WITH ME?! :(
Nah, a couple of members had their s2 turbos shit themselves not longer after they got the cars and wound some boost in.
The main thing that goes in RB20/25 turbos is the exhaust turbine (due to it being ceramic and seeing excessive heat when leant on). I have seen failures of the compressor wheel in s2 turbos but not in s1 (probably due to the fact that it is a steel wheel).
Lastly, if mine can survive the hammering it took on my RB20 AND survive the hammering on the RB30 (where it is actually a restriction, I'm sure the thing must glow when I spend much time around 6000rpm!) it must be a good thing :D
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
