Nissan Skyline R33 1994 GTST 135,000klms $14,990 ono
Performance/Engine Mods: KKR560 Turbo, Custom Made Tuned Length S/S Turbo Manifold, Full 3" Exhaust, Kakimoto Muffler, Front Mount Intercooler, Front Mount Oil Cooler, Powder Coated Rocker Covers, Sard Fuel Pressure Regulator, 660cc Injectors, 800hp Fuel Pump, Apexi Pod Filter, Cushioned Brass Button Clutch, Braided Clutch Line, Turbosmart Type 3 Supersonic B.O.V, Adjustable Cam Gears, Brand New Timing Belt, Brand New Idler and Tensioner Bearings, Gates Silicone Radiators Hoses.........
Interior Mods: Retrimmed Rooflining in Black Satin, Leather Gear Boot/Handbrake Boot, Personal Leather Steering Wheel/Boss Kit, White Face Dials, 3 Gauges in Dash Below Cd Player, Pioneer Cd Player, Apexi Power Fc, Apexi Power Air Intake(Pod Filter),Greddy Turbo Timer, Greddy Profec B Boost Controller, Original Skyline Floor Mats ....
Exterior: Rear Boot Lip/Spoiler, Rear Pods, Side Skirts, Trust Front Bar.
Bonnett and Trust Front Bar Resprayed 20/12/08 By Jetspeed
Brand New Front Windscreen/Seal Rear Windscreen New Seals, Brand New Original Nissan Weatherstips/Cowls Front And Rear, Clear Side Indicators, Very Dark Tinted Windows .....
Suspension/Handling: Tein Coilovers, Cusco Front Strut Brace, Rear Gtr Strut Brace, Hi-Cus Lock Bar, Custom One Piece Tailshaft.........
Wheels: Roh Drift R 18" 265 Rear 235 Front, Brand New Rear Tyres
Car has been tuned and serviced with Unique Autosports & V&E Rigoli.
Also Include Spare boot with spoiler.
Full 12 Months Rego.
I cant seem to attach anything if someone can help out would be great, i have got the car listed on Carsales Vehicle ID 6659974.
Car is Going to get a full detail this coming weekend so ill retake pics after that and again try and list them.
Contact Details
Peter
0409180018
Location Blacktown
Edited by bumpbump
https://www.sau.com.au/forums/topic/255139-1994-nissan-skyline-r33/
    • had 4 weeks off over xmas and well did some stuff to the shed and BRZ, well short of is I don't work full time in supercars anymore as of yesterday.........
    • Did you get any down time over Christmas, or have you had any since to play with this? Or have you given up and are trying to get yourself a second hand V8SC instead?
    • A random thought I had just before I hit "Submit on this post". If brake fluid, in a container in my garage that has never been opened goes bad after 18 months, why can I leave it in my car for 24 months in an "unsealed container"... Secondly, some other digging, and brake fluid manufacturers seem to be saying 5 year shelf life... Me thinks there line on 18 months for an unsealed bottle is pretty much horse shit marketing spin. Kind of like how if you drive a car and don't run a turbo timer your turbo and motor will die horribly...   Where I started on this though... Someone (me) started down a bit of a rabbit hole, I don't quite have the proper equipment to do Equilibrium Reflux boiling per the proper test standards. I did a little digging on YouTube, and this was the first video I found on someone attempting to "just boil it". This video isn't overly scientific, as we don't have a known reference for his test either. Inaccuracy in his equipment could have him reaching the 460 to 470f boiling point range in reality. In the video, using a laser temp gun, he claims his Dot3 that's been open in his florida garage for over a year gets to about 420 to 430 fahrenheit (215 to 221c) Doing some googling, I located an MSDS for that specific oil, and from new, it claims a dry boiling point of 460 to 470f. Unfortunately they don't list a wet boiling point for us to see how far it degraded toward its "wet" point. While watching it I was thinking "I wonder what the flash point is..." turns out its only 480f for that specific brake fluid....   As for testing the oil's resistance, I might not be able to accurately do that unfortunately. Resistance level will be quite a LOT higher than my system can read I suspect based on some research. However, I might be able to do it by measuring the current when I apply a specific voltage. I won't have an actual water % value, but I'll have some values I can compare between the multitude of fluids. I'll run some vague calculations later and see if I should be able to read any reliable amount of current. These calcs will be based on some values I've found for other oils, and see how close I'll need my terminals together. From memory I can get down to 1pA accuracy on the DMM. I don't think my IOT Power Tester has any better resolution.
    • No, with a twin plate clutch flywheels and clutch pressure plate/friction disks go together. Only clutch where that isn't the case is the Uniclutch but they currently don't make a pull version for the Getrag R34, just some other cars. Personally the flywheel is as light as I'd want it to be. It already drops revs faster than I want to shift normally and I blip the throttle again to rev match on upshifts.
    • Are there any other lighter flywheels that can be used with nismo coppermix twinplate system? Id like to gave the revs pick up faster than oem
