yeah thats it, I wonder how they are doing in the recession? rather a lot of cars for sale I see.
but 18 points a weekday, 300 points per year for ~$20k. Whats that? about 16 days in the F430 ..
although I'd be picking cars from group 1 and 2 and stretching my points to 45 days+.
https://www.sau.com.au/forums/topic/255166-ferrari/page/2/#findComment-4404773
They're going ok currently. Yes, the supercar club allow their cars on track - they even organise the trackdays on your behalf. Doesnt get much better than rocking up at EC, getting in the 997GT3 for a few laps, lunch, then the 360CS or F430 (or exige S, or whatever you like) for some more laps later on in the day!
Bargain of a club - and all the guys that work there are (very busy 24/7, can never answer the phone) deadset legends
https://www.sau.com.au/forums/topic/255166-ferrari/page/2/#findComment-4404793
there should be a track day only membership.
I have zero desire to rent a prestige sports car and drive it around sydney but lots of desire to turn up at a track day and drive cars I didn't have to maintain & trailer there etc.
https://www.sau.com.au/forums/topic/255166-ferrari/page/2/#findComment-4404833
Im sure if you have the coin available and are ready to spend it something can be worked out, afterall they're all car enthusiasts and putting the proposal to them doesnt hurt. Ready to sign up? :)
I was going to late last year, then i bought my own money sucking black hole instead..
https://www.sau.com.au/forums/topic/255166-ferrari/page/2/#findComment-4405020
WHo says dealing drugs doesn't pay? He was a wog in his early 30's in bloody bankstown lol even to rent one they are an arm and a leg, gota be over 30 or 35, $25000 deposit bla bla bla....
thats a pretty bogan way to see things !
lol
https://www.sau.com.au/forums/topic/255166-ferrari/page/2/#findComment-4405094
lol, is it a German, Italian, American or Japanese block hole?
the largest black hole there is, my R34 V-spec II, with the nismo R1 hop-up.
taking it to belgarage tomorrow, to get it hks f-con v-pro'd with knock amp ..
someone buy my unused power-fc! please!
https://www.sau.com.au/forums/topic/255166-ferrari/page/2/#findComment-4405354
lol
im not bogan, infact a wog so i know the uy in the ferrari either made it illegally or has something to do with mobile phones or dodgey finance..... no other way he made a 430's worth looking like a thug... yes its closed minded but the chances are i'm correct....
also i'm just jelouse of him lol
https://www.sau.com.au/forums/topic/255166-ferrari/page/2/#findComment-4406252
Ah, yep GTR owners will feel your pain
https://www.sau.com.au/forums/topic/255166-ferrari/page/2/#findComment-4407157
LOL
well i thought u were just being a Bogan redneck...
well if your saying he looked like a HECTIC BRO, FROM BANKSTOWN COUZ.......why didnt you say so?!
Rofl
https://www.sau.com.au/forums/topic/255166-ferrari/page/2/#findComment-4407355
    • To clarify, I meant nismo bushes, not control arms (don't even think that's a thing for my car). So the suspension specialist said, if I buy those nismo bushes which are perfectly centered it will cause my car to veer in one direction. Whereas he said the current offset bushes that I have were put in on purpose to fix that issue. This will be my third wheel alignment if I put these bushes in lol. My chassis is straight, all my rails are clean.
    • OK, well, in that case, the suspension specialist is either a moron, or you aren't understanding what he was trying to tell you. Nismo arms are not really different than stock arms. Both are fixed geometry. I don't know if the Nismo ones are a little shorter than the stockers (or perhaps even a little longer) or the same length, but....if you swap from stock to Nismo, whatever happens to one side will happen to the other side. It will not cause it to steer left or right. That is unless you have adjustable bushes in your stockers, and they happen to be adjusted to dial out some bent chassis shenanigans. But, if that were the case, you'd just put adjustables in the Nismo arms anyway, because Nismo arms are essentially just expensive stock arms. And doing a wheel alignment is just a weekly thing in my world. I have had the suspension apart so many times this year that I've lost count and just about worn out a torque wrench. I'm out in the shed right now cutting up some alloy section and making bases for my new stringline setup. Got to make new swivel plates next, then I'm good to do toe properly, as well as camber and bump steer.
    • Yeah, nah. Not a thing. The gasket between the top of the plenum and the runners is far more likely to blow out when it gets old, and not really at ~14 psi. These things have been run to double that for 30 years without that being a common thing.
    • I plan to pull the intake manifold off and check the gaskets, i read that the block to manifold gasket can blow over 14psi and when i picked up the car it was set to 1.2bar on the controller. Send the injectors out for cleaning. Ill also pull the cam covers off and do an inspection, check some valve lash. Someone also said that the timing belt can rub or vibrate against the belt cover and make that sound. Definitely need to get an AFR gauge on it, if it was lean idling im sure it wont be happy
