Series 2 Rotor Clarification
Recaro sr3 I've always found comfy, compared to my stock r33 gtst and bride fixed back. Can get them cheapish from a Honda owner.
Does your rb gearbox have the common input shaft bearing sound? (One one where it goes away when u push the clutch in or get to higher revs) I heard if you put the wrong oil it can get this sound.
There's more than one way to skin that cat, and most of the sump Maatouks have done will be GTR sumps. They are HUGE in GTR drag racing here.
Yeah...I always start at the shift solenoids, because there's only a few reasons these will spook into limp mode, and bad shift solenoids is one ~ the other can be the shift control module (if you have steering wheel shift buttons)...it's easier to eliminate the solenoids first.
By cabramatta · Posted
Might piggy back off this thread since there's been a good discussion about PWM. I purchased a Walbro 460 F90000267 and have been looking into PWM to understand it. It was purchased more of a future proof as my original OEM fuel pump died (r33 below 200kw) and figured I'd just upgrade it to this. That's when it hit me that a pump this big can cause more dramas with such high amperage draw and heating of the fuel pump being on 100% all the time in such a mild setup. I have a Nexus R3 and slowly collecting power mods but I was looking into the PWM feature on the NSP software: Then looking at the graph from the fuel pump: Am I safe to assume reducing duty cycle to 50% for example would make the pump run like a 230/lph ? Where does the PWM come in all of this ? I've gone down the rabbit hole of PWM fuel pumps and it seems there are many differing opinions on how to go about it 😅
