  • Replies 52
Posted Images
Honest opinion. Not bagging you out or anything..
I would have cropped out that little pole on the left.
I like the idea behind using the history brush tool to bring out the blue sky. But i dont feel its strong enough in this picture to portray anything.
Once again its just my honest opinion and im by no means bagging it out etc..
My sister made the yummiest cupcake thingy.. check out the chocolate spoon she made!!
mr33gts4: yeah i agree with siddr20
I'm assuming thats a rainbow your trying to show but think the photo would be better without doing that (whatever the fancy tool is called)
-dan-: yeah me too! i need a bigger lens (or a teleconverter or whatever its called)
mind you that 2nd one of yours is pretty cool
I think that image sucks.. Just kidding.. Lovely image dude!! Even the mushroom one is nice :blink:
IM about to make a rig for the car. So will be ordering all the parts soonish :D
Cant wait till i start taking some rolling shots etc..
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
