You wont lose your license. I got done doing 135kms on the freeway (I had to get home and go to bed cos it was late and I had work the next day... Never again!!)
It was 5 points and $700. A radar detector is a good idea, but so is slowing down. I''ve lost 11 points in 12 months, trust me, speeding isnt worth it!!
I've paid more on speeding fines then a radar detector would cost :D
not sure in other states but if you get busted with a rade detector be prepared to be raped up the ass
  • Replies 48
* You own a radar detector for one of two reasons ; a) you want to detect people trying to control your mind with a radar b) you want to break the law and not get caught.
I used mine as a tool so I know who's doing what to my car and when and I used the false alerts as a reminder to check my speed.
and also detect government mind-f*k devices :D
i thought it was 82.34867% bubba get ure stats right gosh!!! =P
My bad :)
Mine also alerts me to emergency vehicles with their lights/sirens on.
ahaha best rador deteector is to not speed:)
To own a radar detector means your not relying on your own actions and judgments of speed
I like getting overtaken then undercut by excels and lancers, that's just how I roll :D
P.S. Peeps have many different ways of spelling radar :)
[quote name='bubba' date='5 Mar 2009, 08:31 AM' post='4459283'
Not to mention roadwork crews and other traffic warnings. I never knew all of those signals were being transmitted until I got my detector.
Because without it you would have to rely on lights and sirens, which aren't going to really attact your attention at all.
They obviously don't use flashing lights or beeps to alert the user to Ambo's etc. these ones. Do they punch you in the face instead? If so I am all for this feature being fitted as standard to all radar detectors :)
Edited by rev210
    • The old manifold was quite under the GTR strut brace.  The new manifold is quite [unknown] the GTR strut brace. The GTR strut brace was needed to clear the bonnet vents. The Old strut brace will almost certainly clear the new manifold, but not the bonnet vents. The old strut brace will almost certainly clear the new manifold, and the new bonnet without vents. But I am hoping the GTR strut brace clears the new manifold :p
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
    • This seems like a pointless exercise. There is no E30 availability. Ongoing availability of E85 should not be assumed. Flex-fuel is the only sensible approach, so you can use E85 when and where you can get it, 98 when that's al you can get, and anything in between as you fill it up and drain it down. And if that means replacing the pumps, fitting a flex capable sensor/ECU/whatever has to be done to these Renault shitboxen, then.....so be it?
