Im after some information from people who have used Nitrous before in a small shot.
Im sending my rb30 in soon to be retuned which should net around 350kws at the wheels. Ive got a nitrous kit here that ive had for yonks that i got for next to nothing and wouldnt mind trying it. A few mates have had success with 40/60 hp shots which is what ill be doing. Hopefully ill get around the 380/400rwkw mark.
I will have a seperate fuel map through my computer for the nitrous.
Im interesting in whether its really necessary to have a purge system? If not what sort of delay can one expect before it kicks in?
My next one is whether im going to have issues running the nitrous (if so what issues) running without a bottle heater? I am in NZ (lot colder than AU) and the car may be used for night drags during the summer. The bottle will be mounted in the boot and i have considered a blanket to help retail heat?
Id love to hear from those who have used it before and the pro's and cons of both.
Thanks
https://www.sau.com.au/forums/topic/255263-nitrous-information/
bottle heater is a necessity IMO as it keeps the hit and therefore the NO2 tune consistant, i ran a heater but no purge as i used most of my gas on the street just being a jerk :blush: the softer hit without the purge helped cushion the shock on my auto.... for the first hit anyway :D i ran a 200hp kit on my old clunker but have done a couple of setups on NA 300zx's and supras lately usually 80-150hp.
Good to hear feedback like that. The one advantage of more cylinders i guess is the potential to run more nitrous.
Whats the best way in your opinion to have it setup? Eg on a button or switch on the throttle?
Is there also a correlation between drill bit sizes and the size of the nitrous shot. Have a few small hp fittings here (25hp etc) that are no use, and ive been told you can drill them out.
Any other hints or tips you would suggest?
You always want a wide open throttle switch (as a safety mechanism)
the bottle should be kept at a constant temp, very hard to do. this will keep the mixture correct. as the bottle gets colder the pressure will decrease and it will go rich. nice to keep bottle 850 900 degrees, in youre climate you will need a heater. also a guage on the bottle to monitor bottle pressure. apurge is nice to get a cool shot at the solenoid, happy times!!!!
the timing map needs to be tweaked with timing taken out. You are using a 'wet' system?
You can get yourself another 100rwkw with the fogger if you have the supporting systems and motor build can take it. Going from 350rwkw to 450rwkw might be fun :happy:
You can jewlers drill /file out the jets. All jets should be flow tested anyway to do it right. The NOS brand basic brass flare jets aren't always bang on in size and even NOS themselves at least reccomend flow testing them (very easy backyard test to do).
    • So, I'm not a diff swapsies specialist, but I am pretty sure the 300zx ran an R220 not and R200 like the C34 Stagea, so I think it is of no use to you. As you said, all you need to do is get the centre swapped in the diff you have, which might be best done by a diff specialist. The current centre is probably desirable to someone to track so an easy path might be to swap your mechanical centre for someone with a standard centre (which is a viscous LSD, and almost certainly won't have any limited left). The only thing you have to watch swapping R200 internals between diffs is that the number of splines on your car's stub axles has to match the donor car, or you need the centre+stub axles and make sure they have the same number and pattern of bolt holes as your rear axles.  You swap your current ratio onto the new centre so you don't have to worry about matching the front. Alternatively, centres like the Nismo pro are much gentler (and have adjustable "tightness") so you could buy on of those from somewhere like Jesse Streeter or Nengun (noting it may cost you 1234% extra in tariffs by the time it lands)
    • Id just remove the solid subframe bushes.  you are over complicating things.  on a side note make sure you do some research on the skyline shed before buying from them.
    • Just got back from overseas and once again Rego and service time. Supercheap auto cant find my plates on their list to match my car to buy a crush washer lolol. NRMA has my number plate linked to R35 GTR which i have explained once again that it is not a GTR. Its scary in the sense that if somthing happens and my insurance wont cover me if its the wrong car on their list even though they are the ones that have made the mistake. Im not sure NIGHTCRAWLER why the neg comment? Its a 2020 V37 400R Skyline? and asking for someone to post their VIN number is crazy just to prove it? Its a legit Nissan Skyline from japan factory 400R its does use the Q50 infinity chasis but this is the Japan model.
    • no, you aren't, but good to see you pop by
    • I can also smell fuel in oil if that helps.
