Im after some information from people who have used Nitrous before in a small shot.
Im sending my rb30 in soon to be retuned which should net around 350kws at the wheels. Ive got a nitrous kit here that ive had for yonks that i got for next to nothing and wouldnt mind trying it. A few mates have had success with 40/60 hp shots which is what ill be doing. Hopefully ill get around the 380/400rwkw mark.
I will have a seperate fuel map through my computer for the nitrous.
Im interesting in whether its really necessary to have a purge system? If not what sort of delay can one expect before it kicks in?
My next one is whether im going to have issues running the nitrous (if so what issues) running without a bottle heater? I am in NZ (lot colder than AU) and the car may be used for night drags during the summer. The bottle will be mounted in the boot and i have considered a blanket to help retail heat?
Id love to hear from those who have used it before and the pro's and cons of both.
Thanks
https://www.sau.com.au/forums/topic/255263-nitrous-information/
bottle heater is a necessity IMO as it keeps the hit and therefore the NO2 tune consistant, i ran a heater but no purge as i used most of my gas on the street just being a jerk :blush: the softer hit without the purge helped cushion the shock on my auto.... for the first hit anyway :D i ran a 200hp kit on my old clunker but have done a couple of setups on NA 300zx's and supras lately usually 80-150hp.
Good to hear feedback like that. The one advantage of more cylinders i guess is the potential to run more nitrous.
Whats the best way in your opinion to have it setup? Eg on a button or switch on the throttle?
Is there also a correlation between drill bit sizes and the size of the nitrous shot. Have a few small hp fittings here (25hp etc) that are no use, and ive been told you can drill them out.
Any other hints or tips you would suggest?
You always want a wide open throttle switch (as a safety mechanism)
the bottle should be kept at a constant temp, very hard to do. this will keep the mixture correct. as the bottle gets colder the pressure will decrease and it will go rich. nice to keep bottle 850 900 degrees, in youre climate you will need a heater. also a guage on the bottle to monitor bottle pressure. apurge is nice to get a cool shot at the solenoid, happy times!!!!
the timing map needs to be tweaked with timing taken out. You are using a 'wet' system?
You can get yourself another 100rwkw with the fogger if you have the supporting systems and motor build can take it. Going from 350rwkw to 450rwkw might be fun :happy:
You can jewlers drill /file out the jets. All jets should be flow tested anyway to do it right. The NOS brand basic brass flare jets aren't always bang on in size and even NOS themselves at least reccomend flow testing them (very easy backyard test to do).
    • I don’t really have any ideas how to set the timing on the CAS 😂, sounds like the top, sounds like it maybe misfiring as well as ticking,  got the box sorted 😌, must of been a air bubble on the clutch side
    • Use a 2' length of hose (that's 2 foot, not 2 inches) as a stethoscope to localise the source of the ticking. From cam covers? From exhaust or turbo manifold gasket? From injectors? From lower down in the engine? Etc. Use a timing light to set the timing. Put Redline Lightweight Shockproof in the box. It's not the very best thing for the box, but it will take a box that refuses to engage a gear with other oil, and make it engage a gear. I had to put it in when I installed the R33 box I have in my car. It would not select ANY gear when running. Smurf jizz made it work. That was >10 years ago and I still use it. I'm stuck with it now. Failing that - rebuild the box.
    • Well done Duncan. The fuel tank bulkhead lid is also in great condition (some of mine were stuffed). These are now out of production and good ones like that are becoming hard to come by.
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
