Hey All,
Wondering if anyone has had the same problem as me.
Every time i start my car (or change the vent settings on my CC) I get a weird clicking sound like something is trying turn but is jammed coming from behind the dash.
The car has also stopped blowing cold air. Which is a pain in the arse with this heat.
Any ideas?
ALSO who in Sydney/Wollongong would be the best to send my car to for something like that.
Planning on selling the car soon so would like to have this issue well and truly fixed before listing it.
Thanks :P
https://www.sau.com.au/forums/topic/255335-climate-control-issues-r33/
yeah I thought that it migh be 2 problems i.e electrical and re-gassing ...
I dropped around a air con/auto sparky who said its probably an electrical problem...
They said they could fix it but because there is little info available about the car (no circuit diagrams etc) that it makes hard to diagnose ... thats why i was wondering if anyone had a similar problem ...
find the clicking, more than likely a motor that controls a flap . one of my cars has it, but that flat doesnt change anything.
some motors you can get to without pulling the dash, so you might get lucky.
yeh its a stripped gear on the motor for one of the flaps
I tried finding a bit more info on it cause it seems like whatever electronically controls these flaps thinks that it hasnt opened them and just keepts trying to open them more till some sort of cut out stops it?
I dunno mine does it whenever i start the car now
sounds like its coming from the centre of the dash up near the demister vents ...
sounds exactly right mine does it whenever i start the car also ... wonder if its worth fixing ... I think i'll get a second opinion on my car ... anyone in Wollongong/ Sydney known to do AC on lines?
^^^ wonder if its just an electrical problem not a mechanical one ... hmmm
mine clicks and didnt blow cold air for a while. if u still want the cold air just turn the temp to max the lowest and keep doing it for a minute or so. read up on here to do it and it worked for me. sometime a flap gets stuck to just let in warm air.
it hasnt gotten rid of the clicking sound though. if u have the time id say pull the dash off so u can see everything, start the car, find the part and ask ur air con or sparky bloke for a replacement part. ill have to do it sooner or later too. lol
the clicking sound is the vent flap gear up behind the middle vents, its stripped the gears. Good news? Its a easy fix/part.... Bad news? You have to pull the entire dash out to fix the damn thing... hence why not many people fix it.
The person that works out how to replace it without pulling the dash deserves a freaking medal lol.
(and no I haven't fixed mine either)
The thing that is clicking is called the blend door actuator.
Its a little gear driven vent separator that after time grinds its little plastic stops off and keeps trying to drive past where it should.
Like its been said, its pretty much a dash out job to fix :D Ive heard that unplugging certain cables to the aircon box behind the dash can stop the noise with no adverse effects to the air con, so maybe its worth trying some plugs (one at a time!)??
I have a video of the exact part, so if u get really stuck message me and ill post it on youtube or sumthing :D
    • Yeah, you are right. It seems easier and more reasonable to boost the engine. And as you said the blocks are very similar but the cylinder bores are different.
    • Sound logic, but in actuality way more illegal than just having the wrong pipe. Normally, doing something like that would be forgery. Meaning you may have certain documentation for vehicle parts, but the actual parts are different ones and you just assign them the numbers and badging from the documents. But nevermind that. Nonetheless, I AM curious if this pipe was ever made by any official manufacturer this way, because I honestly am not familiar with this pipe layout and shape. As I will be putting on the HKS Silent Hi Power once my exhaust gaskets arrive, as long as it sounds right I will just roll with this front pipe. I can always order the actual Mines part if I run into legal issues. It would be an unnecessary expense as there is lots of other problems I have on this car as of now.
    • So, weld a plate with the Mines logo laser cut into it, onto it. Instant Mines pipes, whether they were or weren't originally.
    • I don't know if the blocks are "the same". They will be very very similar. Obviously, either the bore or the stroke is going to be bigger on the 20. If the bore is bigger, then the 18 head is unlikely to fit properly. If the bore is the same, then you can almost certainly fit the CA18 head, but there migth be a few fun things you have to do to make water galleries (or other things) line up properly. Or... it could just be real easy. Is it worth the effort? Almost certainly not. You can make nearly as much power on a 2 valv ehead as you can on a 4 valve. There's not any "magic" in a 4 valve head.
    • Yes, me too!!!!  I need to find a something that has all the abbreviations for what these cars have LOL
