Was a shame I only made it right at the end of the day, but still put the car on the dyno and had a bit of a chat with Jamie and a few others that were hanging around.
  • Replies 140
i dont know if its 40kw out or a certain %. My friends 100% standard evo 7 made 150awkw. Does that mean its got closer to 190 with a standard exhaust and standard boost?
A stock standard Evo will not be able to make 190atw. It's probably around the 170ish mark or high 160s.
190kw will require stage 1 mods and increase boost.
However, as many have said, different dynos have different readings.
Edited by sloutch
Hey Antony! I PM'd a pic of your exhaust.
Got some last minute pics.
post-46584-1235350877_thumb.jpgpost-46584-1235350866_thumb.jpgpost-46584-1235350893_thumb.jpg
post-46584-1235350904_thumb.jpgpost-46584-1235350921_thumb.jpgpost-46584-1235350934_thumb.jpg
More so about 145 - low 150ish.
Thanks for that mate, definatly explains alot :blink:
No worries buddy! :D
Yeah thats about right, well at the Kamikaze dyno day, a stock White EVO 7 I saw made about 150 awkW's.
Cuz me and afew friends put a bet on see what it will make and I said 150kW. LOL!
but yeh 200 is easily achieved with an exhaust/cai, ecu and boost.
I was there also (had to go check up on my car thats been sitting there.)
Theres too many variables when it comes to dyno readings so the debate would never stop.
Edited by tenji`
Interesting.
A comparison between my dyno RE Customs and Kamikaze is only 15kw difference.
I logged my run and I attributed it to the fact I had bad fuel and knock.... I've been on holidays for a month, hence the bad/old fuel.
I made 207kw at Kamikaze and 222kw at RE.
The plot thickens =)
Came by at the end of the day and was pleased I could get my car on & off within 20 minutes - no waiting = happy :(
Car is pretty much stock, just a catback exhaust. About 150kw, 11psi MAP reading (my boost gauge reads about 13-14psi, so which one do I use as the accurate figure? Boost restrictor's in place so I figure the lower reading of 11psi is probably right). I figure about 150-160rwkw is about right for a standard gtr, unless someone tells me otherwise?
So you are saying that Dezz's car with a GTRS, injectors, 18psi, etc is really only making 218rwkw. Only 10-20rwkw more than most R33's with std turbo; i really don't think so :(
Or my setup, that is maxing out a 500hp turbo can only produce 284rwkw; highly unlikely.
The dyno is very low reading, but what i thought was consistent, so not all is lost as you can still compare mods to rwkw, between other cars.
Just for the record, with my previous setup, it was dynoed on 3 different dynos (EAS, Autosalon and Racingline) and the 3 read-outs were within 7rwkw of each other. So i am very confident that the EAS dyno is reading accurately.
Maybe it was the way they strapped some of the cars down. My car was strapped that hard that the tyres were well into the guards. This does not allow the car to "climb" onto the front roller and thus will lose traction. With some other cars, the guy running the dyno kept re-adjusting the straps, not sure why he didn't do that with mine as he even commented that the car kept losing traction and the graph clearly shows that at 5300rpm. The other guys that did most the strapping really had little idea, as the main guy kept fixing the straps, when he cbf'd.
same with my car
garrett turbo, 19psi, injectors, pfc etc and making 180rwkw??
i highly doubt it
edit: like i said before standard/standardish cars were making roughly the power they had, where the more powerful cars were down
As long as you use the same dyno to test, thats all you need to worry about etc.
I could get you all a 600rwkw graph for mine, or one with 120rwkw... big deal.
As long as your tuning on the same etc to notice differences, all you need to worry about.
Dyno days are good for a cheap 'check' of AFR/Boost etc
Like @ Dr. Drifts night, i was on 15psi, i thought i was on 12psi, obviously something has changed i need to look at :(
Problem with dynos is that there is no uniform rules on how they should be run etc etc...
whos to know exactly which dyno is the "correct" one.
go run a mph at the strip it will be a good indicator of whether your power is accurate or not.
Like @ Dr. Drifts night, i was on 15psi, i thought i was on 12psi, obviously something has changed i need to look at ;)
I disagree. We're talking about legitamite dyno runs here, not temp sensors stuck near exhausts etc.
You can argue that the results are comparable to other cars run on the day, but even that can be disputed (see Aj's vs nick's for example) but at the end of the day you can't argue that that the dyno was giving low numbers for cars with normally decent power.
Hi all, thought I post my result, my car did 140kw on the day its a stock R34 GTT with std boost, only mod is exhaust not full exhaust system, and pod filter. I thnk wen i put on the Sau sticker i got an extra 5kws on each side. :blink:;)
Either it was my first run and the day was great fun, nice 2 meet some of u guys. :)
Came by at the end of the day and was pleased I could get my car on & off within 20 minutes - no waiting = happy ;)
I was told the dyno was running low on the day at Kamikaze... But ppl are debating weather it is or not...
Friend of mine ran his R32 GTR, which was stock (air box, exhaust, cat and boost) all factory.
He got 155kW at all 4 wheels at RE Customs back in March 2008.
I was expecting alittle more out of the R33 GTR's...
If I were you I would be putting in a aftermarket Down/Front pipes and a high flow cat and it will free up your exhaust a lot more, especialy for GTR's.
+ Other things can effect a dyno run, like doing an oil change will help, check your spark plugs, clean your air filters and the type of fuel you use... A small things can add up...
Guest
    • I was under the impression the reason why OEMs are going with solutions like relatively thin "right-sized" cylinder walls with technologies like PTWA and open deck is because they care a lot about whatever marginal knock margin benefits they get from that vs the structural rigidity benefits of a closed deck block and thicker cylinder walls. I also see some weird stuff like plastic inserts in the water jacket around the cylinders to try and equalize cylinder wall temperatures. re: the PRP blocks and heads at the end of the day it's hard to know what is and isn't going to work there, just have to see what the initial buyers say about it.
    • Which is why I didn't mention that hardness testing, and specifically mentioned the bore and deck thickness testing. Yeah, not really. The bore temperature will be a lot more even around the top half inch or so, where the material distribution is dominated by the deck, and which is the only place where the bore surface temperature heating any gas in the cylinder is likely to have any effect on detonation. Think about it. Another inch or so down the bore, you might have a hotter spot. The gas there might get a bit hotter, then the piston rises squeezes that gas away from there at high speed and mixes it with other gas from nearby. Instant dilution of the problem. I'd be surprised if it was an issue at any time other than in racing engines or OEM dev engines being run at the ragged edge of tuning. Say what now?
    • https://dsportmag.com/the-tech/education/engine-tech-material-hardness-testing/ The PRP testing on block hardness I'm not sure how much it actually can be trusted. The thinner cylinder walls on RBs is a bit of a problem vs 2JZ but it really depends on the design goal. Siamesed cylinder bores like a 2JZ cause uneven cylinder wall temps too, which means a bit of distortion induced by that + the hotspot can affect knock margin. Something that actually gives me a bit of pause with the PRP block, whether super thick cylinder walls are going to keep it from being drop-in compatible on an otherwise OEM rebuild.
    • Yeah very valid point. I am waiting for one of the other tuners to come back from vacation so he can help me a bit when the cat is installed again. In the meantime I am going to finish up my polishing and ceramic coating that I have started myself.    N45 Dr Beasley product is highly recommended for a paint primer / polisher. Using this EXO Gtechniq also for the ceramic but next time might use the light serum before hand also. Looks great.
    • Running rich in conditions where it shouldn't probably won't do great things for catalytic converter lifespan. I would fix that sooner than later.
