Hey guys, recently just had this issue. The problem is that when i put my foot down in 3rd or 4th or any of the gears well mainly the 3rd or 4th(MANUAL), my rev just goes back a little bit like the car dies out but comes back a second.. Could this be my clutch? it feels like a clutch issue. My current mods to my car atm are a Full 3" exhaust with highflow cat, Bleed valve @ 10-11psi, Apexi Pod,FMIC,walbro fuelpump 255l,splitfire coil packs with plugs BCP6RES 0.8mm. Thanks. I was thinking if it was the clutch?
Geraus.
Edited by geraus
Clutch would mean the car rev's up more easily/free without actually going any faster.
To me, basically the same as every other thread on the mid RPM 'hole'.
Your running 10-11psi on the stock ECU so its likely to be having a fit and going into R&R mode (which is impecably well documented)
when im doing about 70kms on 3rd gear full throttle, the car just splutters or for like half a 2nd then clims up ... usually when you put your foot down it just pulls off... now it does some sort of half a 2nd stutter...
i just checked em before. everything is fine, it still goes down like i duno how to explain it, i thnk its the clutch sleeping when i put my foot down......
Edited by geraus
Red bull would really wake up a sleeping clutch......
so it could be the timing? Because it was fine just a couple of days ago............could it be the gearbox?
il try and explain it again.... Just say im on 3rd gear and my rev is at about 3-4prm .. If i plant my foot down, my car will stutter for about half a mili second n then just pull a lil.... sometimes it does it and sometimes it doesnt. .. its wierd...
Edited by geraus
ive got a similar problem. except mine does it in 3rd 4th at about 2-3000rpm. i could notice it more when i got my new turbos put in.
ive been told my car runs lean and the timing retards which causes like a jerking sensation, only for a split second or while im "cruising" and my revs are floating from 2-3000rpm.
correct me if im wrong.
hopes this helps
not a clutch, gearbox or diff issue, its 100% around the engine,
as R31Nismoid has said, check things like spark and timing, AFM, to be honest, could be something to even do with fuel,
say when you put your foot down, it just puts a lot more fuel into the engine then wat its ment to which causes the drop in power because it cant really burn it (splutters), then once thats out of the system 0.5secs or what ever it might be it will burn normal again and you get power back,,
If it was your clutch and you put your foot down, revs will go up, speed will go down becuase your not going anywhere, and normally once it starts burning like that it wont grab at the higher revs,
so take the point of gearbox or clutch completely out,
    • Hey all, not sure how active SAU is anymore but will ask away anyways. Just wanted to get some experience on the 2008 model GTR CBA model.  I've hit that age in my life (43) where I'm like fk it time to get my dream (midlife crisis) car. Looking at importing one in and seeing if these can be reliable if the main flaws are fixed up. Plan is to keep money aside to do the following straight off the bat to future proof it: * install a stage 1 rebuilt trans with all new bits and pieces.  * install a new Bellhousing from the later model GTRs. Or potentially an upgraded stronger version like MAD or ATR. Besides the above two things and typical maintenance items anything else you'd recommend doing.   Been speaking to a few people and the engine on these are very reliable apparently. But keen on the view of the community here. Hoping to find a nice grade 4.5 with low mileage in Grey. I'd go black but swirls too easy. Look forward to your responses and feedback. Cheers
    • Do Alan and Keith work on Skylines now? I remember buying stuff from them when I owned my Ralliart Lancer a few moons ago. Definitely genuine guys and be excellent if they dealt with the skyline platform as well.
    • Hey all, I'm Gaston from Sydney's West.  I was a member on here when I was a younger lad and owned a mint R33 GTS-T. Ended up selling it and getting married having kids (yadda yadda) we all know how the story goes. Now I'm back with the intention to get my midlife crisis (dream) car ... a R35 GTR.  You'll see me about asking questions and searching the forums. Good to be back and can't wait to get back an Import again.
    • I have to put something here in order to post the photos. From what I could gather there's more enthusiasm for modified cars now than there has been for years. There were probably more younger people there than older (me included lol) which was a good sign.  It did seem like the record least amount of representation of the 90's era hero cars on display though. Like maybe one or two examples of S-chassis Nissans, and maybe 3 or 4 R-chassis. By comparison there were a lot of Civics from that era but in all there were about 10 - 12 EG/EK Civic Type R.  Euro exotics are always there in large numbers, led by Liberty Walk...... say what you will about kids using markers to scribble on a Ferrari F40, it did seem like a stunt to infuriate Ferrari enthusiasts, or Ferrari itself. I wonder if there's something more to it. Either way LBWK have done some heinous things to a Lamborghini Miura this time. They should stop now.
    • Engines and drivelines are not war stoppers for me mate, busted arse bodies and un-obtainium parts and panels are though Both cheap Brumbies I looked at had trashed tubs and a fair bit of rust
