  • Replies 62
hey pplz wrecking my 32 GTR car is complete so anything not listed here ive deffinately got but heres the main things.
Blitz SBC - 300
Recaro drivers seat with rail 500
Guards 250 each
bonnet 550
Front bar with lower lip (lower liphas a few chips nuffn major) has nI slots 700
Front bar reinforcing 250
R34 GTR N1 turbos part # 707160-7 minimal shaft pay 1200(pair)
R34 GTR front lower control arms - 300 each
GTR grille- 250
GTR indicators- 150 each
GTR passenger seat - 350
Exhaust control valve- 200
Apexi Stainless steel 3 inch catback exhaust- 700
GTR push type Gearbox- 900
Cylinder head minus cams, cam covers 900
As stated before im wrecking the whole car so if u need anything i havent listed pm me and il get bakc to u asap with a price
All parts located in melb but can send at buyers expense
Hey Mate,
Interested in the 3inch Apexi exhaust, is it still available?
Cheers
Nick
Edited by HELLSCREAM R32 GTR
tried sending a pm but your inbox is full,
i need the whole boot interior, including plastics around the lights,
ash tray, and kick panels,
original airbox if you have it.
and i think thats it.
    • Out of curiosity, what's the reason for converting? I think @R3N3 might have the Frenchy's kit in the R33? I somehow think of you as the ambassador for realistic and clean street-driven setups nowadays
    • careful when running the car after a boil over. Ive heard you can lose enough coolant that it won't show the right temps because of too much air in the system (or something like that). Make sure the levels are good before trying again.  Maybe a mobile mechanic can come have a look with their scan tool ?
    • OK, just for some extra clarity - there is more than one option at Frenchy's. 1. You can buy the whole kit - with or without the actual compressor. The whole kit includes mounts, hoses, condensor, etc. That's either ~$2200 or ~$2800. No surgery required with this option. 2. You can buy just the bracket (~$600), or the bracket with the compressor (~$1200). Either of this or the above option "without the compressor" is if you already have an Echo comp or you are able to source one locally. Whatever the case, in this option, you will need surgery done on your hoses to adapt to the new compressor. When I said "the Frenchy's kit", I meant the whole kit in option 1. It is obviously somewhat more $$ than a $1500 OEM compressor. But if I had to spend $1500 on an OEM compressor, I would certainly consider spending double that to renew and significantly update everything forward of the firewall. Another option is to rebuild your original compressor. My R34 comp is currently dead and I will be most likely doing that to it if the spare one in the shed is also leaky.
    • I’m thinking that’s the route I’ll  go, thanks for the input!
    • Hey all, my 2004 Nissan Skyline 350GT overheated the other day with coolant boiling and leaking out of the coolant reservoir when I was parking. So today, I started it up again just to see if it was a thermostat/head gasket issue. After about 20 mins of running, temps were normal again, no coolant was leaking out and the upper reservoir hose was warm but my engine suddenly cut off. I checked the oil dipstick and cap when it was running and there was no white foamy residue and the exhaust did not have white smoke. I tried starting up the car again but it would only crank, similar to when I had a camshaft sensor issue just that now there’s no check engine light on the dash. Any ideas? Unfortunately I don’t have an OBD2 that can read the Nissan's programme.
