hi Zilla, you may want to try again with the perspective positioning of the front bar, engine & rear wing.
The wheels are good if you Photoshlopped them on, but fine tune the gold overlay. Front Bar changed.
On the front bar, I selected the yellow, just using the magic wand, and then using Hue/Saturation to make it greyscale -
just used the saturation slider all the way to the left & click OK, with the eye dropper I took a colour sample of the front panel,
then used hue/saturation again, clicked the colourize box which matched the slight blue in the panels, click OK.
I then used Levels to get the right depth in colour.
Edited by Motorhead
as above, get a photo of the front bar you want on a similar angle to the car your trying to put it on, also, instead of the magic wand tool, use the pen tool, its far more accurate for selection, to colour the bar i suggest using multiple layers of the same image with different blending modes for each layer,
As above, use the hue and saturation to make it Black and white and then duplicate the layer a few times, set the Blending mode for each layer to something different till you get a colour that looks more like the rest of the car.
    • That dirty voltage drop is the culprit I suspect
    • i cant get them all in 1 screenshot unfortunately as i just dont know how to move things around tbh, but they are all from the same log and the line crosses at the same point for all of them
    • It's about time I start work on my sun tan. So I knocked up a few parts that will all combine together to become my new power steering reservoir. Now just to produce an abundance of UV and IR rays while melting a heap of bits of alu to become one... Well, that's after I put one more hole in it for the return line to plumb to. It likely won't be this weekend, as Sunday I'm meant to be in doing some last minute stuff to the AMG race car, and the weekend after will be filled with non my Skyline stuff, followed by Bathurst 6 hour. So I don't expect to get to melt metal for at least 3 weeks.   I also managed to stuff up and start cutting the hole for the res to pump pipe on the wrong side of the line... It means instead of the lines being nice and tight against the inner guard, they'll be out off the guard.    The size of it means I should end up with about 1.8L of power steering fluid, and still have space for another half a litre before it reaches the overflow/breather. This is wayyyyyyy more capacity than factory, which should help keep Powersteer oil temps lower, and the design hopefully allows it to prevent any aerated oil being able to makes its way down to the bottom as it'll have a couple of baffles and some hopeful trickery to force air bubbles away from the bottom.
    • The log you did with ECU voltage, can you log the other things too like rpm and oil pressure? Need all that info together to compare easily
    • Editting as I hit post to soon, and this will lock out otherwise.
