Howdy. I've got a S2 R33 GTs-t here in sydney for wrecking. It's had a hit up the back, so the tail lights, rear bumper, and bootlid are gone.. rest of the car is up for grabs though. If youre after anything send me a PM or reply here! Pics at the bottom of this post
It's a '97 S2 R33 Gts-t with approx 146000 ks, Silver/KR4 in colour.
BBS Impul wheels + Falken tyres - $1000 ono
17x8 and 17x9. Rear tyres are on the tread markers, fronts have about 40%. Unsure of offset as its not written anywhere on the wheel, but they fit R33s perfectly. great condition, just a few small gutter marks
5sp Manual gearbox. Shifts well, no crunching. Includes slave cyl, crossmember, shifter and tailshaft - $1500 ono
Can sell as a manual conversion kit if anyones keen
Front end stuff:
S2 front bar - paint has flaked/chipped off in some places, needs respray. includes foglights - $350 ono
S2 grille -SOLD
Front guards - $100 each
S2 headlights - $500 firm pair
S2 bonnet - $250
A/c condenser - $150
Radiator & shroud - $100
Front reo bar (has been cut for FMIC) - $120
Radiator support/ nose cut - $150
Engine bay stuff:
S2 Rb25 turbo with actuator, good cond, minimal shaft play. Didn't blow any smoke - $250
Impul Hi power control unit remapped ECU - $200
S2 Rb25det engine loom - $150
S2 Rb25det coilpacks - $100
S2 AFM (pink sticker)- $90
R33 aircon compressor pump - $100
R33 power steering pump - $100
R33 alternator - $80
Engine Mounts - $80
Fuse box lid - $20
Washer bottle - $20
Radiator overflow bottle - $20
Charcoal canister - $30
Stock airbox & snorkel + filter - $75
Stock SMIC piping - $50
Stock sidemount intercooler - $40
S2 ABS pump - $100
Bm-44 ABS brake master cylinder - $80
Exterior & suspension/brakes:
Side mirrors - $50 each
Rear SKYLINE garnish (silver) - $40
S2 spoiler minus brake light - $50
Stock suspension with lowered king springs - $250
Front lower control arms - $70 each
Front upper control arms - $40 each
Front hubs - $80 ea
Rear lower control arms - $50 each
Rear 5 stud hubs - $160 pair
Handbrake assembly & cables - $160 pair
Manaual (4.11) ABS diff - $250
Driveshafts $50 pair
Rear upper arms - $50
Front calipers - 250
front rotors - $50
rear calipers - $150 pair
Rear rotors - $50
Interior stuff:
Boot interior, sides, floor, carpet etc - $100
Drivers door window switch - $75
Drivers window switch surround - $40
Drivers door motor/regulator - $80
Passenger door motor - $50
Door trims - $50 each
Instrument cluster with 300km Impul speedo. Unfortunately odometer has stopped (everything else works though) - $150
Dash surround (with clock, hazard switch etc) - $80
Gear stick surround - $50
Ashtray - $25
Glovebox - $40
Steering column surround plastics - $30
S2 dash pad (with passenger airbag & panel) - $350
S2 Steering wheel with airbag - $250
Centre console - $50
Front seats (drivers side has a tear in the usual spot) - $100
Rear seats, good condition - $50
Seatbelts, full set - $80 (will seperate)
Ignition barrel + door barrels + key - $100
If you're chasing any little random bits that arent listed, shoot me a PM. Cheers
post-35556-1233651201_thumb.jpg post-35556-1233651214_thumb.jpg post-35556-1233651188_thumb.jpg post-35556-1233651118_thumb.jpg
https://www.sau.com.au/forums/topic/255421-wrecking-s2-r33-skyline/
  • Replies 68
Do you have the sideskirts? Interested if you do.
Sorry mate the car didn't have sideskirts
Drivers side swtich, window motor/reg and switch surround sold pending payment
Will add some more pics soon!
interested in the manual conversion kit, how much would you want for it?
Hey, PM sent
hi could u tell me about the computer , is it running stock boost
Hiya, as far as I know it was runnning stock boost
Hi
I am after the motor that makes the mirrors go in and out (passenger side). Is this a part of the mirror assembly?
Could I get photos of the mirrors, drivers and passangers.
Also do you have the break light for the S2 rear wing?
Cheers
sent u pm last night..
keen on brakes..
Heya, Pm replied
interested in ecu...wot sort of gains were seen with this place? fuel economy?
is the silver rear garnish is good condition, where u located?
cheers
Sorry mate not sure of the gains as it was never dyno'd or anything. It would have a more agressive fuel map, modded timing, speed limiter removed etc
Silver garnish is in great nick. Pm sent
Hi
Cheers
Hiya, I'll get some pics of mirrors tomorrow for ya. Just looking to sell the mirrors complete (with glass, motor, shell etc)
Don't have the brake light sorry, just the spoiler by itself
cheers
Heya, Pm replied
cheers
Still after pics of mirrors, want to see the condition (scratches)
    • Yeah. I believe the fear of annealing the alloy and weakening it, Every online discussion has someone saying it's bad and potentially a risk when powder coating forged wheels.
    • I'm interested if anyone agrees with what you've said, and can give a good reason. Temperature of powder coating should be below any temperature you'd use to alter the wheel structure.  Powder coat typically 200 to 250. Annealing if that's what people are claiming would be occuring, starts at 300, and depending on the alloy, can need even up at 400+.   That's the only part I can think of that could cause an issue that people are believing it's from the rim losing hardness and becoming too soft.
    • Negative probe should be on the cars chassis. Positive on the wire.   Start as said above by unplugging everything (unplug the lights, and switches. Now at the switch, there is a wire from the fuse, to the switch, so out your positive on that terminal. It should read open circuit. If it reads something, especially a stupid low value, the short is somewhere between the fuse and the switch. If that's fine, now put the positive probe on the wire that goes to the headlight (at the switch plug). If it reads stupid low, the fault is from the switch, to the headlight.   Another quick test, is take the whole LED light setup from the left, and plug it into the right side, does it still blow the fuse? If you put the right hand side led light setup on the left hand side wiring, does the left hand side wiring now blow?  If the blowing fuse swaps from right to left doing this, your LED lights are the issue.
    • Anyone know if it's a problem to powder coat forged alloy wheel centers (Rays/Volk GT-C). some say it's bad and can damage the alloy, some say it's not a problem.
    • Hey guys, I'm reviving an old post but I'm finally getting around to working on this now. I removed the battery to get a better look at the wires and i traced the wires from the headlight to the fuse box in the engine bay, but the wiring looks fine? The wiring for the R/H headlight is 3 wires and then is bundled up with the large diameter wire that goes underneath the fuse box. I didn't take it apart yet. I know you said that its a short circuit somewhere between the fuse box and the headlight. But could it be the headlight switch on the dash? Also, i pulled out my multi-meter and set it on the Ohms, but i'm not sure where to put the negative probe and the positive probe.
