Wrecking S2 R33 Skyline
Howdy. I've got a S2 R33 GTs-t here in sydney for wrecking. It's had a hit up the back, so the tail lights, rear bumper, and bootlid are gone.. rest of the car is up for grabs though. If youre after anything send me a PM or reply here! Pics at the bottom of this post
It's a '97 S2 R33 Gts-t with approx 146000 ks, Silver/KR4 in colour.
BBS Impul wheels + Falken tyres - $1000 ono
17x8 and 17x9. Rear tyres are on the tread markers, fronts have about 40%. Unsure of offset as its not written anywhere on the wheel, but they fit R33s perfectly. great condition, just a few small gutter marks
5sp Manual gearbox. Shifts well, no crunching. Includes slave cyl, crossmember, shifter and tailshaft - $1500 ono
Can sell as a manual conversion kit if anyones keen
Front end stuff:
S2 front bar - paint has flaked/chipped off in some places, needs respray. includes foglights - $350 ono
S2 grille -SOLD
Front guards - $100 each
S2 headlights - $500 firm pair
S2 bonnet - $250
A/c condenser - $150
Radiator & shroud - $100
Front reo bar (has been cut for FMIC) - $120
Radiator support/ nose cut - $150
Engine bay stuff:
S2 Rb25 turbo with actuator, good cond, minimal shaft play. Didn't blow any smoke - $250
Impul Hi power control unit remapped ECU - $200
S2 Rb25det engine loom - $150
S2 Rb25det coilpacks - $100
S2 AFM (pink sticker)- $90
R33 aircon compressor pump - $100
R33 power steering pump - $100
R33 alternator - $80
Engine Mounts - $80
Fuse box lid - $20
Washer bottle - $20
Radiator overflow bottle - $20
Charcoal canister - $30
Stock airbox & snorkel + filter - $75
Stock SMIC piping - $50
Stock sidemount intercooler - $40
S2 ABS pump - $100
Bm-44 ABS brake master cylinder - $80
Exterior & suspension/brakes:
Side mirrors - $50 each
Rear SKYLINE garnish (silver) - $40
S2 spoiler minus brake light - $50
Stock suspension with lowered king springs - $250
Front lower control arms - $70 each
Front upper control arms - $40 each
Front hubs - $80 ea
Rear lower control arms - $50 each
Rear 5 stud hubs - $160 pair
Handbrake assembly & cables - $160 pair
Manaual (4.11) ABS diff - $250
Driveshafts $50 pair
Rear upper arms - $50
Front calipers - 250
front rotors - $50
rear calipers - $150 pair
Rear rotors - $50
Interior stuff:
Boot interior, sides, floor, carpet etc - $100
Drivers door window switch - $75
Drivers window switch surround - $40
Drivers door motor/regulator - $80
Passenger door motor - $50
Door trims - $50 each
Instrument cluster with 300km Impul speedo. Unfortunately odometer has stopped (everything else works though) - $150
Dash surround (with clock, hazard switch etc) - $80
Gear stick surround - $50
Ashtray - $25
Glovebox - $40
Steering column surround plastics - $30
S2 dash pad (with passenger airbag & panel) - $350
S2 Steering wheel with airbag - $250
Centre console - $50
Front seats (drivers side has a tear in the usual spot) - $100
Rear seats, good condition - $50
Seatbelts, full set - $80 (will seperate)
Ignition barrel + door barrels + key - $100
If you're chasing any little random bits that arent listed, shoot me a PM. Cheers
post-35556-1233651201_thumb.jpg post-35556-1233651214_thumb.jpg post-35556-1233651188_thumb.jpg post-35556-1233651118_thumb.jpg
  • Replies 68
sent u pm last night..
keen on brakes..
Heya, Pm replied
interested in ecu...wot sort of gains were seen with this place? fuel economy?
is the silver rear garnish is good condition, where u located?
cheers
Sorry mate not sure of the gains as it was never dyno'd or anything. It would have a more agressive fuel map, modded timing, speed limiter removed etc
Silver garnish is in great nick. Pm sent
Hi
I am after the motor that makes the mirrors go in and out (passenger side). Is this a part of the mirror assembly?
Could I get photos of the mirrors, drivers and passangers.
Also do you have the break light for the S2 rear wing?
Cheers
Hiya, I'll get some pics of mirrors tomorrow for ya. Just looking to sell the mirrors complete (with glass, motor, shell etc)
Don't have the brake light sorry, just the spoiler by itself
cheers
 Share
