  • Replies 193
Posted Images
G'day guys im fairly new to motorsports and im just wondering how me and a mate would go about just coming down to watch to get an idea about what its all about?
Any help would be great
Spectating is free and more than welcome at DECA...So head to Shepparton, turn up at DECA anytime between 8am and 4pm and enjoy the show :D
You can also introduce yourself to some members, and if you're lucky someone might offer you a ride as passenger on the skidpan :P
Well my car is off the road again..
But that wont stop me from being there.
In saying that.
If any of you guys/gals want to come to DECA and help out that would be fantastic.
We will need people to be Officials on the day .
Forget about just coming down for a look. As soon as you see the skidpan you'll wish you had entered. This is grass roots motorsport. You can go as slow or as fast as you like and it's all for fun. Just put in an entry form.
Passengers are allowed all day, but must sign a passenger disclaimer form, and also must wear a helmet.
On another note the SAU motorsport committee will be keeping a close eye on the weather leading up to this event. If the forcast is for 40+ degrees we will be looking to postpone / cancell this event.
It's just too much for us to ask officials to stand out in that heat for even a couple of hours and most cars wont appreciate it either. Hopefully the forcast is for a warm day, but not as extreme as last weekend.
When is the latest I could confirm by fax and pay? I need to make sure my car will be ready for then. Unless it's refundable?
Sorry to pester - just wondering if someone could answer this?
I'd say as long as the list is not full but it'll very helpfull if you can fax your application in in advance so that the Motorsport committee can have a rough ideas of how many entrants have they got on hand.
Thanks for the replys guys ill defiantly try and get down on the day and have a look.
I'd love to enter a car down there but the lancer needs some new tyres and in bad need of a new clutch
but as soon as its fixed ill be up for some events.
    • I was under the impression the reason why OEMs are going with solutions like relatively thin "right-sized" cylinder walls with technologies like PTWA and open deck is because they care a lot about whatever marginal knock margin benefits they get from that vs the structural rigidity benefits of a closed deck block and thicker cylinder walls. I also see some weird stuff like plastic inserts in the water jacket around the cylinders to try and equalize cylinder wall temperatures. re: the PRP blocks and heads at the end of the day it's hard to know what is and isn't going to work there, just have to see what the initial buyers say about it.
    • Which is why I didn't mention that hardness testing, and specifically mentioned the bore and deck thickness testing. Yeah, not really. The bore temperature will be a lot more even around the top half inch or so, where the material distribution is dominated by the deck, and which is the only place where the bore surface temperature heating any gas in the cylinder is likely to have any effect on detonation. Think about it. Another inch or so down the bore, you might have a hotter spot. The gas there might get a bit hotter, then the piston rises squeezes that gas away from there at high speed and mixes it with other gas from nearby. Instant dilution of the problem. I'd be surprised if it was an issue at any time other than in racing engines or OEM dev engines being run at the ragged edge of tuning. Say what now?
    • https://dsportmag.com/the-tech/education/engine-tech-material-hardness-testing/ The PRP testing on block hardness I'm not sure how much it actually can be trusted. The thinner cylinder walls on RBs is a bit of a problem vs 2JZ but it really depends on the design goal. Siamesed cylinder bores like a 2JZ cause uneven cylinder wall temps too, which means a bit of distortion induced by that + the hotspot can affect knock margin. Something that actually gives me a bit of pause with the PRP block, whether super thick cylinder walls are going to keep it from being drop-in compatible on an otherwise OEM rebuild.
    • Yeah very valid point. I am waiting for one of the other tuners to come back from vacation so he can help me a bit when the cat is installed again. In the meantime I am going to finish up my polishing and ceramic coating that I have started myself.    N45 Dr Beasley product is highly recommended for a paint primer / polisher. Using this EXO Gtechniq also for the ceramic but next time might use the light serum before hand also. Looks great.
    • Running rich in conditions where it shouldn't probably won't do great things for catalytic converter lifespan. I would fix that sooner than later.
