Micolour Sau-vic Deca Motorkhana - Sat 28th Feb 2009
Scotsman
 Share
  • Replies 193
Posted Images
G'day guys im fairly new to motorsports and im just wondering how me and a mate would go about just coming down to watch to get an idea about what its all about?
Any help would be great
Spectating is free and more than welcome at DECA...So head to Shepparton, turn up at DECA anytime between 8am and 4pm and enjoy the show :D
You can also introduce yourself to some members, and if you're lucky someone might offer you a ride as passenger on the skidpan :P
Well my car is off the road again..
But that wont stop me from being there.
In saying that.
If any of you guys/gals want to come to DECA and help out that would be fantastic.
We will need people to be Officials on the day .
Forget about just coming down for a look. As soon as you see the skidpan you'll wish you had entered. This is grass roots motorsport. You can go as slow or as fast as you like and it's all for fun. Just put in an entry form.
Passengers are allowed all day, but must sign a passenger disclaimer form, and also must wear a helmet.
On another note the SAU motorsport committee will be keeping a close eye on the weather leading up to this event. If the forcast is for 40+ degrees we will be looking to postpone / cancell this event.
It's just too much for us to ask officials to stand out in that heat for even a couple of hours and most cars wont appreciate it either. Hopefully the forcast is for a warm day, but not as extreme as last weekend.
Sorry to pester - just wondering if someone could answer this?
I'd say as long as the list is not full but it'll very helpfull if you can fax your application in in advance so that the Motorsport committee can have a rough ideas of how many entrants have they got on hand.
Thanks for the replys guys ill defiantly try and get down on the day and have a look.
I'd love to enter a car down there but the lancer needs some new tyres and in bad need of a new clutch
but as soon as its fixed ill be up for some events.
Guest
 Share
    • People still have Skylines? I thought they're non-existent now.
    • Harness update time have had great fun and learnt so much already so far with this project. I started off making both the ignition and injector sub harnesses in the hope any mistakes i made here aren't as hard to undo and learn from as the main harness.  A cool comparison of the old harness using presumably TXL wire and the new which is using Tezel. Also opted to use DTM plugs to keep the whole setup as neat and tidy as possible and tucked the wiring under the coil bracket to try and keep it all from sticking out too much. Although the injector harness, I'm not overly happy with as I'm still using the rubber boots that are supplied with the type of plugs it just looks ugly and sticks out like a sore thumb with the white identifiers so a slight redesign may be done.   Then it was main harness time and most importantly trying to route it nice and away from the heat it will use the OEM heater hose routing which is no longer present to keep the harness up high and secure. it's amazing how much smaller this harness is able to be compared to the old one. plugged everything into the emtron and with the help of the tuner again attempted to start it up and instantly fired up and running smoothly on all 6 which was a big shock to myself. So still some routing and adjusting to be done for the final fit up and installing a knock sensor harness plug which is in the post all has gone surprisingly well.     The old harness for shits and giggles.
    • They do that at random every now and then, with almost no detectable cause. Mine has done it a couple of times (over 25 years!!). Never worked out why.
    • I don't post on here and have been lurking for some time now. Many of the topics have helped me out more times than i can count. I was racing yesterday (11/9) and blew a front right CV shaft. I have spares so I popped a new one in. A thread i read previously said to check the engine mounts if you blow a front CV. Upon inspection, the front right mount was completely separated from the upper plate. This discovery saved me time and money, because i would have blown another CV if i went back out. Just wanted to thank you guys and wish everyone luck with with their builds. (Now if we could only come up with a solution for my power steering belt flying off after hitting the rev limiter, lol)
    • Either way he still need those style of spacer to go into the manifold because the photo he currently has is not going to work
