yes i have read that
it does not list the illumination wire
the stock loom does not have one (i guess), so i'm trying to source one, as my butchered loom has lots of not stick wire colours,
Typically
Yellow is 12V(constant power)
Red is accessories(key set to accessories)
Orange is Illumination(headlights)
that said, the best way to be sure is as follows:
grab a test light from super cheap or repco (no more than $10)
-switch your key to the 'on' position
-turn on the headlights
-test your wires one at a time by touching the positive prong to the wire and the negative prong to a good earth point on the chassis, (should be plenty around the head unit area)
if done correctly 3 wires should cause the test light to light up, these are your CONSTANT POWER, ILLUMINATION and ACCESSORIES.
switch off the headlights with the key still set to 'on' and test those 3 wires again, only 2 of them should work, the one that doesnt work is your illumination.
that's a really odd color for your illumination, that said, if you tested all of your wires using a test light as i stated you would still be able to work out which 3 were illumination, constant power and accessories
  • 2 years later...
Typically
grab a test light from super cheap or repco (no more than $10) Never use a test light on a modern car, you will trigger the airbags or fry the ECU etc in a heartbeat. by blind probing wires. for under 20 bucks you can get a cheapo digital meter !!!
    • All I can say Duncan is good luck and I hope that Neil did not run any E85 in Cheryl. I have recently experienced the full spectrum of fuel tank issues in my R33's that had been caused by E85 and contaminated fuel. When you take the cover off the top of the tank and have a look inside you will get an understanding of how easy it will be. Best case situation is clean fuel with minimal contamination. My GTR was like this and it was a very simple operation to just grab the fuel pump carrier bracket and slide it up and out of the tank. My three GTS_T's had different levels of fuel contamination that was probably caused by E85 in the fuel.  In the worst case all of the metal components in the tank had rusted to the point where there were pieces of rusted metal swirling around in the tank. This required the removal of the exhaust, the tailshaft, the complete rear cradle and the fuel tank. The components in the tank were that rusted that it took days to get the fuel pump carrier and the mounting brackets out of the tank. When the tank was finally cleaned, everything inside the tank had to be replaced. With the tank all back together I could then reinstall it in the car along with everything else that had to come out. Good luck and I hope that you find a clean tank.
    • It is a two door. It is black and also still has the OEM wheels and stereo. Exact model would be KR_R32RGFEL_SS According to GTR-Registry.com is a 2 Door Coupe; RB20DE; 2WD no HICAS; MT.F5; (11L) Projector Headlamps and Fog Lights; (12_) Electronic Active Full Auto Air Con (Climate Control); (13-14SS) V Selection -- Which seems to be accurate description of my variant. Will try to upload a few pictures soon. The OEM wheels look like the below image. Image is taken from the goo-net-exchange website.
    • Time: Saturday 18th January - 9am -10:30am Where:  Cafe By Lamanna 10 English St, Essendon Fields VIC 3041  - https://g.co/kgs/mhVKvAB Registration: So we can give the cafe a heads up on rough booking numbers please rsvp below Registration Link: https://forms.gle/wPtfj9Gp8bvCiouo8
    • Welcome Gabriel. At least your car has a glorious RB and not the shitty CA18. As MBS206 mentioned all the good bits can be added later. Two doors or four?
    • And half of them have been converted to turbos.
