hi all,
have up for sale my hks cast low mount external gate manifold.
said above is basically it, um its covered in some kind of high temp coating, and is in practically new condition. fairly rare, i kno i hadnt seen one of this till i had one.
please note, this item is for r33 rb25det, i had slight problems with mounting it to my r32 rb25, changing the position on the turbo made it foul on my chassis rail and strut tower (view relevant pics). actualli when u look at it, its only the actuator that was making the trouble, my plan was to block off the ext gate part and run an internal... anyways depends what turbo u wanna run as to what will fit in what and all that jazz...
THIS IS MADE FOR AN R33 RB25DET, if u wanna try and put in on something else its up to you :(
cost - $600 firm.
history - bought this item early december from a fellow sau member, from my knowledge he never used it, and cant remember where he got it from. my plans were to put it on my r32 rb25, however as stated above, this manifold was designed for an r33 engine bay, in mine there is simply not enough room.
reason for sale - as stated above, didnt suit the application i intended it to. now im in the process of changing to top mount.
location - adelaide (north east).
p/up or delivery - would obviously prefer a local buyer, but if not freight can be arranged at buyers cost.
contact - ben (me) via pm, message here or call or txt me on 0438554500
https://www.sau.com.au/forums/topic/255468-hks-cast-manifold-r33-rb25det/
if someone can confirm it will fit rb20 im interested
the bolt pattern ie manifold-engine is exactly the same for rb20/25.
depends what turbo setup you want to use :)
as you can see my poor choice of trying to use internally gated did not work so well.
if u bolt an externally gated turbo you will have alot more room down stairs than i did.
Edited by theminuz
For the record i've got one of these manifolds fitted to my r34 rb25neo using an old hks t3 turbo. We had to shave the engine mount slightly but it fitted up easy enough. It's a great upgrade
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
