For sale Datsun 240K coupe (club car), L24 with triple 40mm DCOE webers, with ram tubes, big cam which allows it to rev well, shaved head, reconditioned ignition system, extrators, 2.5 inch exhaust with hotdog, 240z or 240k 5 speed (not sure but smooth), 4 point roll bar welded hoop but bolted in (not logbooked), some suspension work, Twin spot front brakes, R31 rear disk conversion, reconditioned master cylinder, standard locked diff, 4 point harness on drivers side with race seat, twin thermo fans. Body is in reasonable condition and has some rust in the lower rear guards and has a some minor damage behind right hand rear wheel and in sills, body could do with a tidy up. Car is very competitive at club level events.
$3,500 ono
Call Andrew
Home(03)54612549
Mob 0448254553
I'd say judging by the phone no, it's in victoria. Better yet, give him a call
My memory is a bit crapola due to the huge amount of beer that I consume, but wasn't this 240k sold on ebay for 2.5G about a year ago? I seem to remember that the plate on the firewall (the one with the VIN etc.) had gone AWOL, making the car non-road-worthyable/race car only in Vic.
Correct me if I'm wrong, my memory really is a bit on the vague side.
Don't know if it's the same one, but just because it's missing the compliance plate does not mean it can't be registered. There are mechanisms in place to let you register a car that's missing its tags.
    • I'm firmly on the "zero compliance is good compliance" for FUCAs. I'd be looking to solid metal joints even if the primary reason for having them is because they facilitate the twist in the arm. I have never been more happy with the way the front suspension behaves than I have since I got rid of the FUCA bushes. Even the thin little (short lived) poly bushes in the Whiteline adjustables have too much compliance for my liking. It probably won't be long before I have sphericals nearly everywhere, probably including both top and bottom arms in the rear, and I'll start complaining about the increased costs for dental work. But I will be enjoying the driving more, I'm sure.
    • Plus, you'll get great experience in bedding in pads!
    • I have offset Nismo brackets so the fact the gktechs can pivot is less important to me. I have 170mm JIC arms with bushings - but they provide no adjustment and I'm not sure whiteline eccentric bushings will fit them (I don't want to ruin the bushings currently in them to find out). Ideally I want something with bushings + adjustment; hence why I'd like to find a pair of these. Unfortunately they aren't easy to find.
    • @Vee37 How much do you really care about finding these pads again? If your pads are quiet, work well and produce minimal dust, really isn't that enough? If you are set on finding the exact pads again, I suppose I'd do something like this -  Visit your local Jax, find out what brand of pads they carry. If the Jax workshop you previously went to had the pads on the shelf, then you can almost guarantee it will be of said brand.   I'm guessing you don't have the receipt for the previous work and pads. Can you visit a Jax workshop and see if they can look up your previous job to see what pads were fitted?  Still no luck? Put your stalker hat on, find the staff that used to work at the Jax store and ask them. Talk to local workshops, try to find out where the mechanics went to. Talk to Jax workshops, maybe they relocated to another workshop. When it comes to mechanics, its a small world. You'd be surprised how easy it is to track someone down. If these ideas don't work, shit will start getting crazy very quickly.... You could find out every brand and model of pad that fits that car... and try them individually ticking each off the list if it wasn't the one you were looking for.... If you go down this path your going to want to learn how to swap pads yourself, it is very easy, takes minimal tools and space. If you have room to park the car you have room to swap the pads. Plus you have the advantage of making sure all the brake hardware goes back in so they won't squeal!
    • You miss spelled bearings...
