Hi, im listing a few R33 that i need to sell ASAP. They are priced very cheap to sell fast. Located in Campbelltown-Sydney.
Engine Bay + Suspension:
A/C Compressor + Lines up to firewall $45
Power Steering Rack $75
Power Steering Pump $45
Brake booster $50
Master cylinder $45
slave cylinder $40
Wiper motor $35
Bonnet lock assembly + supporting bracket $25
Bonnet hinges $10 each
Washer Bottle $15
Coolant over flow Bottle $15
Charcoal canister $15
Front Wheel arch covers $5 each
Front calipers $35 each
Rear calipers $20 each
Front hub assembly $50 each
Exterior:
Bonnet (small dent in middle, grey in colour) $50
Passenger door $40
Boot lid + flat spoiler $40
Left Guard $35
R/H Tail light $40
Headlights (side bracket broken on both to accomadate for 400r Bar) $10 each
Guard indicators-amber $10 each
Wipers $5 each
Driver and passenger windows $30 each
Exterior door handes $15 each
Antenna + motor $25
Petrol lid/cover $20
Interior:
Door trims $25 each
Inside door handles $15 each
Climate control unit $40
Steering Wheel (3-spoke) $15
Indicator Control switch module $25
Wiper & washer Control switch module $25
Side vents $5 each
Rear/back seat $40
Rear/back trim $25 each
Steering column surround $20
Under steering covers $15
Centre A/C vents + surrounds $20
Centre Console $20
Dash board (no cracks) $50
Dash instrument cluster 121000 (GTS) $40
P/window switch control (driver window button doesnt spring down, but operates fine) $10
P/morrors switch control $15
I have other parts that I havent mentioned, so if your in need of something thats not listed just ask and i might have it, thanks.
https://www.sau.com.au/forums/topic/255510-r33-parts-going-really-cheap/
  • Replies 49
I take the
-steering well columm surround,
-steering wheel and
-door trim,
-driver and passenger windows
-and Headlights (side bracket broken on both to accomadate for 400r Bar)
Cheer dude
Edited by sybrix
    • Before you blow your car up, have you checked you've made all the correct modifications to the wiring if you're still using the RB20DE loom?   Some things to look at: The pin used for the map sensor on the RB25DET, is the same pin used on the RB20DE for the Ring Gear Crankshaft Position Sensor, no idea what you've got it plugged into now. The turbo pressure control valve solenoid you're talking about on the RB25DET, the same pin is used for the Variable Air Intake Control Valve on the RB20DE.   The factory manual has the wiring pinouts in it for you to check everything. It also has the diagnostics process to read codes out. In addition, there's a great table that shows what sensors and what actuators not functioning will relate to which signals. And Nissan confirm the as everyone else has from experience, the Solenoid being disconnected won't cause a fuel cut. However, the turbo pressure sensor being missing / wrong, WILL cause a fuel cut. https://www.nicoclub.com/service-manual?fsm=Skyline%2FR34-Workshop-Manual-English.pdf
    • I've been hunting info on the G Series II - this is best I have found so far(Link below). Still waiting on the G35-1150 comp map, kind of very keen   So how do we go about getting precision on that little table of yours ?   https://turbosbytm.com/sites/default/files/product/technical-info/Garrett-G-Series-II-Product_Flyer 25 30 35_1.pdf
    • yeah I get ~0.6L per session into the catch can. very ethanoly. It ends up overflowing out the breather of the catch can on circuit days too even with a 2.3L capacity catch can and I only drain out ~0.6L max. So every session I have to come in and drain the catch can, which is a hassle. So this is me cracking the shits and doing everything I can without removing the motor (back of head sump drain/breather and oil restrictors off the table). plans short term are: full length splash plates remove oem cam cover baffle add foam and reinstall at -10 or -12 AN fittings to the side of the cam covers down to the sump (luckily I already have fittings in the sump) Yes the ~340,000km unopened motor is probably not helping things
    • I'd use any fuel safe foam....mine went in 15 years and 15 rebuilds ago, still getting reused I'd have to say I don't understand swapping to studs to fit a particular baffle unless you are having a massive blowby issue, and even if you are addressing crankcase not head breathing is probably the next step.
    • BTW, the reason I came in here to "update" this list was that the Garrett G Series II range have been released and I've updated the list with their flow details if you're curious to check how they fit with previous Garretts and other brands The G-Series II G35 990 looks like a banger...
