  bloodsword27 said:
i heard Haltech was releasing a new range therefore leading to the price drops. is this true?
They are realeasing a Platnium ECU it is all over the Haltech website.
Cheers
Johno
  • Replies 78
As far as im aware there is no limit on ECU's, but it is a limited time offer and is only valid until the 17th.
You can use paypal but it will incur a 5% fee.
Cheers,
Johno
Is this a genuine group buy or simply a dealer trying to shift current stock in readiness for new product.
After speaking to my local haltec dealer he insists its the latter and can do these prices as long as haltec have stock.
Either way its a hot price for a damn good product.
This is a genuine group buy, I work for an Investment Bank not a workshop/dealership etc. The opportunity came up to do the GB at great pricing and here we are.
Our GB has upset a few re-sellers, but theres nothing wrong with a bit of competition especially for the end user.
Cheers,
Johno
gave haltech a call today, the new platinum sport 2000 is rrp $2445 (sumting like dat). the guy recons the sport uses new circuits and has map sensor built in, no need to buy seperate. similar features to e11v2 just with newer technology and some extra features, i didnt get into the tech details of it.
An E11V2, a map sensor and your away..
I've been advised Haltech do not have many ECUs left, so if your keen act now or miss out.
Cheers
Johno
Ladies and Gents,
The Haltech GB will be closing shortly, due to overwhelming response Haltech are now running low on stock. We have secured numbers for all GB participants.
I am awaiting payment from the following users, can you please make payment ASAP so we can get the ball rolling.
liampire
JJay
doomedjest
crappin
black200is
All other payments have been recieved, I will be sending you all a PM to confirm your orders and addresses.
Cheers,
Johno
Cheers mate,
Payments recieved from:
JJay
doomedjest
Outstanding:
liampire
crappin
black200is
There are only two E11V2's remaining, If you want one get in fast or you will miss out.
Cheers
Johno
Sorry mate, not enough interest in that unit to get group buy pricing.. you will have to contact Haltech for a price..
Cheers
Johno
liampire - paid
crappin - part payment
black200is - withdrawn..
I'll be contacting all participants within the next 3 days to confirm postage details and arranging pick ups.
If there is any others interested pls let me know asap, ecu's are in short supply. I will be collected them on Tuesday and the GB will be closed.
Cheers
Johno
  J said:
liampire - paid
Cheers
Johno
awesome
we should see them by Friday the latest
nice work dude!! :rolleyes:
    • It is hard to be specific half way across the world...but it *seems* like it might have a minor issue. Is the idle stable and does it rev smoothly? I would not expect any pops out of what I am assuming is a standard ECU, standard tune, standard exhaust. You can use Nissan Data Scan to find out exactly what is happening when it runs, the cable/software is reasonably affordable if you are not planning on changing the ECU (which hopefully you are not with an NA skyline) BTW your mileage may not be that far off, these are heavy old tech cars, and being NA might mean you use a heavy foot to keep up with traffic....
    • Hey guys! Y'all are the masters so figured I'd check in on a few items here. - My engine sounds ever-so-slightly more raspy than the other NA RB25s I've listened to. It's barely noticeable but definitely a slightly different sound. - When I back off the throttle at high RPM, I will sometimes get a pop out of the exhaust, assuming this can be diagnosed as misfire. Some history on the car: - Had an exhaust leak in auction sheet but was claimed to be fixed by seller (bought from USA importer).  - Car's coil packs and sparks were replaced when it was sold to me, but unsure on what the gap is and whether the coil packs are correct.  - A prior mechanic had misdiagnosed a pilot or throwout bearing sound as LSPI/detonation. Had played with timing a bit, pops/raspy sound of engine just got worse. Got timing reset. - Had failed emissions a few times. First time went in as is, failed. Second time, replaced cat, still failed, running rich as hell. Third time replaced o2 sensor, passed. Car still smells gassy though. - Timing belt and valve cover gasket also replaced.  - Gas mileage is... low. about 350-400K per tank.  Any idea if I'm having any serious issues here or does this all sound like normal old NA RB stuff and I'm fine to drive it with the pops/slightly raspy engine? If it'll help, I can get drop a video of the sound of the engine.
    • So....to find any R chassis part number, get your VIN (will be something like ER33-xxxxxx for you) and go to: https://www.amayama.com/en/genuine-catalogs/nissan and enter it. From there you have access to a web version of Nissan's part system, FAST. It is a bit tricky to get used to, so maybe have a shot and post up what you think.  You can also search by general model but note in some cases your car might have different options so VIN is safest.  On diagram 211 I got 14075-75T16 for Connector, Water Hose If I search for part 14053‑21U10 that you posted, that is also a water hose but not the one bolted to the plenum and 14075‑04U00 is the fitting where the water hose goes into the block.
    • Yeah now we are talking I much prefer coolers in the front middle because it lessens the chance of a small bump to a corner stopping the whole event. I was thinking the AT cooler can move out of the radiator, delete the AT/engine coolant interwarmer and mount a separate cooler with a thermoswitch somewhere further back as is common in racing, that would be one thing. Beyond that, the engine oil cooler is an obvious one to move to the wheel arch, potentially one on each side, but unused space is an issue. I did have a earlier pic with the bumper off but it doesn't show how busy the corners are: DS is full of the auto driving sensors and PS is totally fully of windscreen washer fluid reservoir But ultimately I was hoping to keep the AC, and the water/air heat exchanger is fundamental so it is not just the radiator that needs to be in front BTW here's airflow to the rad as it ran at the track (one horn is gone now and I'll remove the lights next time):
