quick question my brother has a broken drivers side mirror glass for sometime now and wants to get it fixed
i went to a wrecker today and got told that u need to change the whole mirror
i dont think thats rite as u can change the 32 ones
is this right??
https://www.sau.com.au/forums/topic/255540-changing-34-mirror-glass/
When the wrecker said you need to change the whole mirror, did they mean just the piece of glass/mirror or the whole side rear view mirror casing unit including the glass?
I think you can just change the piece of glass. Get a flat head screw driver and hinge out the glass to see if it will pop out... Take it easy as you don't want to dent the plastic casing around the mirror.
Also be aware of the electronic mechanisim that allows you to adjust the angle of the mirror, you don't wanna damage it.
Yeah..?
i changed mine yesterday very simple you dont need to take off anything
as mentined above get a wide flat head screwdriver and place it underneath the mirror, or adjust the angle of the mirror so you can fit your fingers in. theres 2 clip thingys at the bottom of the glass (behind the mirror), 1 on the center right and 1 on the center left so just get the screwdriver/fingers in there and push it out 1 clip at a time
if you use the screwdriver you might wanna put some rubber or somethin on the head so theres less chance it'll snap the glass...
