dones anyone know the Size/Pitch/Offset for the standard V35 Sedan Rims?
thanks
WTB: 2003/2004 or 2005 Nissan Skyline V35GT Sedan with the 3.5litre V6
Manual 6 Speed Gearbox
Leather pack for the Seats
Factory Sunroof
Factory Bose Stereo System
Silver, Charcoal or either of the Blues in Colour
40-50K Maximum mileage
Xenon Headlights
  • 3 months later...
Sorry to dig this thread up, but I'm a NOOB with respect to rims and want to ask what offsets are required for each width for a V35 Skyline Sedan? I am looking to buy some rims and keep getting mixed messages on the offsets that will suit without modification.
FRONT - Max Offset? Min Offset?
8" rims
8.5" rims
9" rims
REAR - Max Offset? Min Offset?
8" rims
8.5" rims
9" rims
9.5" rims
10" rims
So far, I've been told (via various for sale posts and other websites):
FRONT
8" rim = +17 Offset will fit
8" rim = +30 Offset will fit (standard 350z 18" rim offset)
8.5" rim = +23 Offset will fit
8.5" rim = +25 Offset will fit
8.5" rim = +29 Offset will fit
9" rim = +25 Offset will fit
REAR
9.5" rim = +27 Offset will fit
9.5" rim = +29 Offset will fit
9.5" rim = +30 Offset will fit
9.5" rim = +35 Offset will fit
10" rim = +25 Offset will fit
Do you now see why I am confused? Any help will be appreciated.
And, how do you know if rims will clear big brakes? I may upgrade to a big brake kit in future and don't want to limit myself now by buying a rim that doesn't do the job later.
Also, with tyres, under what circumstances would you use 45, 40, 35? Obviously, the larger the diametre of the rim, the thinner the tyre. So, does this mean:
18" rims = 45 tyre?
19" rims = 40 tyre?
20" rims = 35 tyre?
Or am I wrong?
Whilst we are on tyres, can someone now clarify what width tyres fit on:
8" rims = 225 tyre?
8.5" rims = 245 tyre?
9" rims = 265 tyre?
9.5" rims = 275 tyre?
10" = ?
Maybe once someone can answer my NOOB questions, this can be posted as a sticky for all V35 owners as a quick ref guide or something...
Ok firstly, the wheel offset guide I posted above should be your guide as to what fits and what doesn't. I have however managed to achieve a little bit more with slightly more aggresive offsets.
Secondly my advise is based on your car being lowered at least 1" all round. If you are lowered more than that you will more likely be able to squeeze in a lower offset wheel.
8" rims up to +28 before requiring fender roll
8.5" rims +30 no fender roll
9" rims +35 no fender roll
8" rims
8.5" rims +33 no fender roll
9" rims +37 no fender roll; +31 fender roll (245 tires)
9.5" rims +40 no fender roll; +35 fender roll
10" rims +45 or + 50 no fender roll
If in doubt you can use this calculator to work out how much your new wheels will move toward or from your fender.
http://www.1010tires.com/tiresizecalculator.asp
Ok moving on to brake clearance. If you are buying Jap wheels, Work, Rays, SSRs etc, they usually state disk type
Normally denoted by A = Standard disk (will clear factory v35 brakes), O = Super low (fine for the rears), R = Hi Disk for BBK or Brembos
If you are planning on upgrading brakes, then it would be in your best interest to buy wheels that have R disk or Hi disk
Check this spec sheet as an example:
http://www.workwheelsusa.com/media/wheels/26/72/VSKF_PDF.pdf (note wheels with super low brake clearance are normally ones with bigger dish)
Finally tire size and profile:
Needs to conform to factory Overall Diameter or else it will throw your speedo out.
Use 245/45/18 as your base spec. + or - 15mm is OK.
Then go to the tyre calculator to work out what you need if you go 17s or 19s
If you are planning to run big widths and aggresive offsets, you will also need to choose smaller width tyres to avoid scrubbing eg: rears 245 instead of 265
Disclaimer: The above advise is still fairly conservative with regards to offsets. If you want to dump your ride and run -3 degree camber and stretch 225 tires on a 10" rim you can still achieve most of the below offsets. :down:
Hope this helps.
8" rims
8.5" rims
9" rims
8" rims
8.5" rims
9" rims
9.5" rims
10" rims
FRONT
REAR
18" rims = 45 tyre?
19" rims = 40 tyre?
20" rims = 35 tyre?
Or am I wrong?
8" rims = 225 tyre?
9" rims = 265 tyre?
10" = ?
Excuse my ignorance but I thought the fronts were already rolled from factory? Unless you meant removing the inner fender "protector" things and rolling it further since those plastic fender covers are screwed onto the guard... I'm planning to fit a 9.5" +22 wheel up front with around 1-1.5 degrees negative camber and 225 tyres, do you reckon it's possible without removing the fender covers? I'm almost certain it'll rub at full lock :P
Edited by 350GT-ATE
I think you might be right about the fronts already rolled. I have only rolled my rears.
Going 9.5 at the fronts you will have two problems. Too high an offset the inner rim will hit the suspension. Go lower offset and it will stick outside your guards like dogs balls.
Check out the chart above.
9" at the fronts would be optimal. You really don't need to go any wider at the fronts or you'll have problems steering the damn thing :P
Any info in regards to the coupes?
I've been looking a set of wheels, 10" on the rears and 8.5 or 8" on the front, offset +22 for the 10" ones according to site. Would like that I'd not need to roll my guards.
Cheers!
Cheers!
Coupe guards and wheel specs are similar to 350z = massive potential!
9.5 +22 F and 10.5 +22 rears not a problem at all.
    • My take on gg2 48mm, 54mm, 58mm, and 62mm compressor map for same size compressor vs gg1 : All gg2 only outflow gg1 above 20 psi. As all g gen 2 surge line at lower left of comp map move to the right, all gg2 sacrifice spool vs same size gg1, surge line move to the right worst for 54mm gg2. So for same size compressor if you want best response, use gg1, if you want max hp at >20psi use gg2 but you will be laggier vs same size gg1. Max compressor efficiency drops to max 75% on all gg2 vs max 76%-80% of same size gg1. Iirc lower efficiency means hotter iat less dense air so lower hp at same operating point of comp map. Also curious why gg2 is mapped to lower max rpm vs same size gg1 (only 48mm size both gg1 gg2 mapped to same rpm) : 54mm gg1 165,000 rpm  vs  gg2 160,000 rpm. 58mm gg1 150,000 rpm vs gg2 140,000rpm. 62mm gg1 145,000 rpm vs gg2 140,000 rpm. If gg2 can safely spin to gg1 rpm then they can flow a bit more than as mapped. Good thing that all gg 2 interchange compressor and turbine housings with same size gg 1. So gg1 owners can buy gg2 chra only if planning to boost >20psi.
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
    • A thing I wasn’t happy with with enthusiast was during the initial phone call they told me they’d insure it for 130k but needed photos.   I then sent them photos and they told me $80k as there were other cars either similar modifications available for around that price, I told them to send me the links to said cars so that I can buy them. i then sent the modification list with prices of the parts (no labor) and the price then came to 115k, which is still shy of the 130 that was agreed in the initial phone call
    • Ask me a bit later this week before payday
    • I agree that delayed payment probably isn't the most suitable solution. It seems a solid complete transaction would be best. As I wouldn't be using this sale as a line of credit that would typically earn interest, we can probably arrange a much cleaner single transaction deal. I can do $92.52 today. Would you prefer EFT, or Cash on Pickup?  😛
