  • Replies 80
  • 5 weeks later...
Check on here: http://forum.r31skylineclub.com/index.php?topic=123760.0
I don't know if it is going ahead, but it's rather close now.......... Easter is next week.
It will not suit everyone, a date and time just needs to be set and go from there. If they turn up, they turn up! if they don't, they don't.
Edited by StinkyPoo
Yes its still a go'er.
Going out on Saturday and Sunday to look at the best spots and the will post the results, times etc on Sunday night.
Waiting to get the "Long Range" weather report as well to finalize time's.
Again have the 4 days to choose from but will take into concideration of the days you wont be available.
Will keep you posted.
Alan.....
;):D:)
As promised details as listed:
Easter Sunday
Time: 9am (Nice and early so to miss the crowds)
Where: Old Dept of Taxation Car Park
From there we go down to the fountains below Old Parliment House.
There is plenty of room for you to take individual or group shots of cars.
From there to the Car Park at the bottom of ANZAC Drive.
You have the lake in the background.
Then up to the top of MT Ainslie.
For those that wish to, then a cruise to a nominated BBQ area for lunch or what ever.
If your still interested please let me know via this thread.
:wacko:
Had very little interest so far but I will be there tomorrow.
Want to get some of the GTS anyway so if anyone else shows shows up all and good.
9 AM tomorrow.
See you if you show up.
Alan
The photo shoot is tomorrow KAT .. ya haven't missed it just yet
But here is a pic I took of my skyline a little while ago near old parliament house
Just resized it so I could post it up quickly ..
my car looks a bit different now ...
Fully blacked out window tint and no rear wing now
Ahhh I thought it changed to Saturday cause of the rain that was forecast! :banana:
That looks really good btw. I'd love to get my baby up there between the trees it's a nice spot.
Edited by GTRKat
    • 49719 is the cooler loop. Right at the front, LHS of that diagram. Return line from rack (LP side) goes to cooler loop on RHS front of car, then back under engine and returns to bottom of tank. 49717M is feed from tank to pump. HP line out of pump is thick rubber, followed by the hard line that runs down to crossmember and runs in parallel (but opposite flow direction) to the LP return line. Nothing goes anywhere near the firewall or interior of car. The closest they get to that is the connections on the rack.
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
    • Don't worry about. Just don't try to drive hard enough to make boost and you'll be fine.
    • Yes. This has already been said. It is a loop of hardline in front of the radiator. Because.... the pump is on the LHS and the steering rack hydraulic connections are where they always are on a RHD steering rack....on the RHS. The high pressure line goes down under the engine, along the crossmember, like it does on all Skylines. Don't just throw expensive braided hoses/other kits at it. Work out what is wrong and fix that.
    • Still got the afm on the intake, clamps are shut tight, only loose hose is the one that goes from the j pipe towards the IACV, since it's next to impossible to find a factory hose and the barbs are different sizes (I'm still using clamps on this hose to try and help it seal on the iacv side) I've ordered parts to make up the hotside of the intercooler pipes, I'll plumb it in and see what happens in a few days I suppose The turbo's internally gated, can I just unscrew the tension rod to let the gate open?
