  • Replies 79
Andrew here (0407 201 729, Sydney). Do you still have the below available:
- Ashtray (does it have the clip to lock it into the centre console)
- Glovebox (my locking latch attached to the glovebox has broken)
- Front & rear strut braces
You got plastic undertray, wheel arch liners and stock intercooler duct by any chance?
PM me if you do have them.
Cheers
Grant
  • 4 weeks later...
    • Hi, is the HKS  Tower Bar still available ? negotiable ? 馃
