im about to start srtipping my 32 everything is for sale here are just some of the things going of the top of my head but theres prob more so just ask if your after anything
engine 180 000 k's split fire coils standard turbo $700 ono
gearbox $300 ono
diff $200 ono
tien suspension $400 ono
sructbraces front n rear $100 each ono
rollcage $500
hicas lock bar $50
r34 standar suspension $200 ono
r32 aluminium radiator $200
32 std radiator $50
r34 std radiator $50
r34 front sway bar $50
r32 std ecu $50
interior bit everthing bar air con vents let me know what your after n i'll give u a price??
apexi pod filter $100
sterring wheel $50
boss kit $50
exitior bits let me know what u need n i'll give you a price
reclinable seat $50
full 3" exhaust system with screamer pipe $200
these are just what i can remeber if your after any thing for a 32 let me know n i'll see if i have it
https://www.sau.com.au/forums/topic/255569-r32-stripping-n-selling-parts/
how thick is the hks cooler and how do the pipes run to the intake?
im not sure man i'll check the size tomoorw n send you a pm the piping is fitted to the stand piping so its pretty a bolt in kit to standard
how much you chasing for both c pillar trims and are they in good condition as mine are screwed.
ther not in the best condition man looks like the owner before me tried to cover them in black leather n they have started to peal off a bit im sure the could be fixed n they look different to any i have seen before you can have them cheap it you want dude
I think I got my pillars mixed up, I might be the A pillar trim I am after. If you scroll down to the last photo of the first post on the link I add it is both of those trims I need. I have heard people call them C pillar trims and A pillar trims so yeah I am little confused.
http://www.skylinesaustralia.com/forums/R3...im-t230270.html
It doesn't bother me if the material they are covered with is peeling off its just more if the back of them is fine as mine are all broken so I can't retrim them.
Edited by Triptych
what do u wanna know about the kooler man it was in the car when i got it so i dont have much info on it , not sure about sun roof mate mine doesnt have one n i havent seen the inside or one with a sunroof to say, yer hicas lock i still have
anymore info on the cooler? also u know if the cage suites sunroof or not? will take the hicas lock bar if u still got it
    • Selling a genuine Nissan Skyline R33 Coupe 8-Pin Power Window Master Switch Part No. 25401-26U10 Price $300   IMPUL Gear Knob – Rare JDM Upgrade Upgrade your interior with this genuine IMPUL gear knob – a rare and stylish addition to any JDM build. Premium quality, perfect fit, and an authentic Japanese touch for your ride.  Price:$300 Nissan Skyline R33 (Series 2) Sedan Tail Lights Immaculate Condition OEM JDM S2 a pair of OEM Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state. Price:$900   Located in Melbourne (Western Suburbs) – Shipping available Australia wide at buyer’s expense. DM if you need anymore details.
    • KYBs are typically twin tube, putting them in the lower tier of desireability. Do you just want to replace worn out ones for the lowest cost? I mean, you wouldn't just replace one end of a car, if the rears are a similar age to the fronts, then they are probably nowhere near what they should be, and likely won't be great against brand new fronts. So, to spend ~$800 on 2nd tier dampers, when you could get a decent set of MCA coilovers for <$4k.....? As to the strut tops. 1st up, the Sparesbox site specifically tells you that they are not correct for an R33. Beyond that, why do you think you need them?
    • That's not very Toyota of the Toyota!
    • Bringing an old thread back to life Looking to put some new front shocks in the r33Gtst and the KYB still look ok for a road car. Unless there are any other options aroind that price $200 a shock?  I’d like to replace the strut tops also, is this the correct KYB no. For the strut top, KSM7124?  https://www.sparesbox.com.au/products/kyb-strut-top-mount-ksm7124?srsltid=AfmBOoq-HDru8wSlLnQrhU9gCw_uYdKg8gUQzONY-EQOdnI5iXOWEUjY 341287 appears to be the front KYB shocks part no.  thanks all
    • LandCruiser used to get a fluid flush every 12 to 18 months.   Only because it was about that often the electric motor on the master for brake assist kept dieing and needing to come off.
