R32 Stripping N Selling Parts
tysliner
 Share
im about to start srtipping my 32 everything is for sale here are just some of the things going of the top of my head but theres prob more so just ask if your after anything
engine 180 000 k's split fire coils standard turbo $700 ono
gearbox $300 ono
diff $200 ono
tien suspension $400 ono
sructbraces front n rear $100 each ono
rollcage $500
hicas lock bar $50
r34 standar suspension $200 ono
r32 aluminium radiator $200
32 std radiator $50
r34 std radiator $50
r34 front sway bar $50
r32 std ecu $50
interior bit everthing bar air con vents let me know what your after n i'll give u a price??
apexi pod filter $100
sterring wheel $50
boss kit $50
exitior bits let me know what u need n i'll give you a price
reclinable seat $50
full 3" exhaust system with screamer pipe $200
these are just what i can remeber if your after any thing for a 32 let me know n i'll see if i have it
how much you chasing for both c pillar trims and are they in good condition as mine are screwed.
ther not in the best condition man looks like the owner before me tried to cover them in black leather n they have started to peal off a bit im sure the could be fixed n they look different to any i have seen before you can have them cheap it you want dude
I think I got my pillars mixed up, I might be the A pillar trim I am after. If you scroll down to the last photo of the first post on the link I add it is both of those trims I need. I have heard people call them C pillar trims and A pillar trims so yeah I am little confused.
http://www.skylinesaustralia.com/forums/R3...im-t230270.html
It doesn't bother me if the material they are covered with is peeling off its just more if the back of them is fine as mine are all broken so I can't retrim them.
Edited by Triptych
what do u wanna know about the kooler man it was in the car when i got it so i dont have much info on it , not sure about sun roof mate mine doesnt have one n i havent seen the inside or one with a sunroof to say, yer hicas lock i still have
anymore info on the cooler? also u know if the cage suites sunroof or not? will take the hicas lock bar if u still got it
 Share
    • There is a LOT of stuff that can be done, it all depends on how much time and money you want to spend on doing in.  Not all ECUs will be able to do it, and the more control you need the more time and knowledge needs to be put into making it work.  If you're willing to spend the time and money and have the right hardware and skills involved there's a lot that can be done.
    • I am impressed with all this level of adjustment. I didn't expect all this possibility
    • Correct.  In the case of the 500kw dyno plot I showed you the car actually runs two boost control solenoids for boost control and a 5psi wastegate spring.  It allows me to control how much boost pressure is applied to both sides of the wastegate valve at any point and fairly accurately control boost target as a result. I've tuned it so that it's able to target anywhere from 5psi to 25psi depending on what's needed.  The target tables I've set up in that car are Gear vs RPM, so every gear has potential for a different boost (and torque) curve.   First and second gear have quite low boost targets, third gear actually has different target boost all the way through the rpm range as it's a stock RB25 gearbox - the boost targets have been chosen to maintain a peak of 600nm (what the owner has set as the maximum torque he's happy with putting through the stock 3rd gear) but it carries that to the rev limiter.   The boost curve to achieve that is something of a ramp up, then hold, then ramp up again and the power curve looks more like a flat line haha.
    • so you can decrease or increase the boost depending on the diet as you wish?     by acting on the wastegate?
    • That's torque and power, it's all from a single run.  The boost curve is "held back" from it's peak target in the 3500rpm to 5000rpm range from memory, so it ramps hard to something like 18psi then climbs more progressively to 23psi nearer 5000rpm.   It makes the torque (and power) ramp more "natural" and less hard on parts and traction, it doesn't feel artificially held back.
