do u want the wheels in your guards or "fully Sick Offset Styles".
A nice 18 x 9 +20ish and 18 x 9.5 or 18 x 10 in a +32 ish offset will be perfect.
With the front you will need a big caliper clearance disk. So will have small amounts of dish on the front. but for the rear you can get a low caliper clearance and have max dish on the rear if you want.
Up to you.
And also up to your budget.
Come down and See me at Wheel Worx on Port Road.
Any further q's dont hesitate to ask.
18" Inch Work Meister S1 2P for an R33 GTS
Any advice on sizing and offset help would be appreciated.
Wanted to put Bridgestone potenza's on aswell
I would avoid those tires, I have some on my R34 they dont wear well and are slick in rain and dry. and sound like a dump truck in the noise dept. plus there plus the cost a bit ?
if you do a search there was a thread about tires not long ago ?
my two cents worth!!
I can't tell if this is a wanted to buy thread or not. If it is, there is a thread specifically for wtb.
And yes, do a search - the topic of wheel size/offsets, and tyre brands has been covered 1,000,000 before
^^^ lol.
i dont think its a question of do u wana fill ur guards, its do u want ur wheels to 'fit'. shadow spec isnt correct fitment.
anything can be shoe horned under the guards, take mine for example haha.
Up to you.
im guessing u work at wheelworx lol. what u got in the way of 19x8.5/9 +20/30ish in 3 pieces. and rough prices?
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
