Adrian’s (4MY SON) Memorial Cruise
22nd March 2009 at 11.00am
Carousel Car Park, Albany Hwy
Hey guys n girls,
Hard to believe that its been 2 years already how time has flown, but now its time for a cruise so everyone can get together and look back on the past years and reminisce.
I would like to invite you all to attend this cruise which is being held to raise money for Canteen who supports families with children who have cancer.
We have organized this cruise in memory of Adrian so we can all visit most of his favorite places around Perth.
This cruise is going to be open to ALL makes/models & car clubs so SPREAD the word as far as you can, the bigger the better.
Gold coin donation will be needed for maps which will be handed out on the day, as the money is going to a good cause I don’t see this as a problem.
The main meet point will be Carousel shopping centre, Woolworths end behind the CALTEX service station we are meeting at 11.00AM and departing at 11.30AM SHARP
Thank you and hope to see you all there showing your support for a wonderful cause…
Heather, Nev, Steve, Matt & Kara
https://www.sau.com.au/forums/topic/255581-adrian-lee-4my-son/
  • Replies 56
thanks for all the support guys n girls :) i def hope to see yas all there in force... if u see a Purple n Grey (black if you cant see colours well) s13 silvia you cant miss it just look for the 4MY SON stickers... come n say gday 2 :) i dont bite
Yo jamie man i didnt realise J TUNED was your car haha i seen it around a bit ages ago... hope you make it aye... i really gotta get around 2 fitting that catch can before the cruise 2 :D haha
Edited by Travis_morris
  • 3 weeks later...
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
    • Sorry for reviving an old post, but I'm having the same hot idle tick issue. Did anyone ever find out what it was?  I have checked/ replaced Injectors Coils checked Lifter clerance (is at zero) Checked Cam lobes Replaced exhaust gasket and studs Would appreciate any advice this is driving me nuts
    • There's a huge reason manufacturers are tuning in dead flat torque curves... Make them reliable (and more drive able)
