  • Replies 53
Hey guys, do you know where I can find it?
Almost had to push my car home when I found out at my local BP. Had to fill up with Vortex... ewww
yeah had some issue.
No BP, no mobile, no vortex 98
no shell near by, had to put 95 octane in.
M
https://www.sau.com.au/forums/topic/255596-bp-ultimate/#findComment-4408272
lol so confused honestly bro not to scrutinise but...it makes no sense lol what did u find out at bp...seems like you found out bp was caltex lol
https://www.sau.com.au/forums/topic/255596-bp-ultimate/#findComment-4408279
bp in kew has been out the last two times ive been there
so i have to go down to the shell in camberwell
im not sure why it's out though..?
BP on high st mavern between tooronga and glenferrie is normally fine :happy:
https://www.sau.com.au/forums/topic/255596-bp-ultimate/#findComment-4408610
I asked the guy working at mobil, he said that there is a 98ron shortage in victoria for some reason, so mobil and bp whom share the same fuel refinery are gonna be all out pretty soon. Next shipment is meant to be Friday, so the guy said. Vpower will have to do until then!!
https://www.sau.com.au/forums/topic/255596-bp-ultimate/#findComment-4408700
Will find out today and try and post up during business hours but can only access SAU via the iphone.
Was planning to do so anyway as I went to Elwood and Kings Way last night for Ultimate. Then Kings Way Caltex and no Vortex 98 so ended up heading to Todd Road Shell for V Power. :happy:
https://www.sau.com.au/forums/topic/255596-bp-ultimate/#findComment-4408757
Hahaha, sorry should have been more specific. Found out both BP stations near my house have run out of BP ultimate - my usual fuel. Still the case today.
So if there is no BP ultimate, what would people recommend as the next best 98? Did a search, but didn't turn up anything.
https://www.sau.com.au/forums/topic/255596-bp-ultimate/#findComment-4409715
Any 98 will do
https://www.sau.com.au/forums/topic/255596-bp-ultimate/#findComment-4409754
Any 98 will do
Really? I always heard that BP ultimate was the best, and the overwhelming majority of Jap car drivers seem to use it in preference. Considering they're all similar price, I just stuck with it because it would have a lower probability than the others of being an inferior fuel, as well as being the most populous service station around my area.
Don't know what it's worth, but certainly BP ultimate has a lot more info on the website vs the pathetic one paragraph descriptions of Vortex/V-Power/Synergy 8000, which all seem to have been written by the same guy. Most likely BP has better web designers/marketing managers, but it doesn't hurt.
I did here something about all of them coming from the same refinery, but I guess the difference is the additives they put in?
Edited by Phatboy
https://www.sau.com.au/forums/topic/255596-bp-ultimate/#findComment-4409792
    • Just be warned that that turbo will not be a direct re-fit to the car. The exhaust housing is, of course, in the same place. It has to be - it's bolted to the exhaust manifold. So the dump will fit up. But the centre housing is not as long, so the comp housing will move backwards. This will affect both the turbo inlet and the outlet. There is fab work that needs to be done. Yes. it has one, it should have one. Paper gasket.
    • I only recently purchased the vehicle, it came with the flex setup but the current tune is e85 only, which is why im wanting to get the tune redone to enable a mixture.  First i need to get the exhaust redone tho. I was thinking of getting a varex muffler but it sems they dont fit well in the 33 (hang low because of the valve mechanism which sticks out on top) and generally dont sound good. So that leaves me with redoing the entire exhaust (more resonators and mufflers) so its not a menace when i come and go from home, and then have the aes dump valve somewhere along the line to really open it up. I was thinking of having it before the cat but after seeing how insanely loud it will be (on a vl turbo) im thinking of putting it more towards the rear of the car, after one of the resonators.
    • At this point I'm just 'hoping' it's the turbo seals. I did speak to someone who said it's normal for these turbos to have a bit of axial play? Not gonna lie I've never checked a turbo for axial play before but you could hear it tapping a bit as I moved it back and forth. Surely that's too much? My theory is (could be completely wrong), bad axial play, worn bearings, bad seals, oil into dump/compressor side, burns in exhaust = blue smoke. On a timing belt related note, my crank pulley was missing that front plate that sits in front of the timing belt. It's that metal round plate. It did have the rear one, and the woodruff keys are in the crank which was nice. Can anyone confirm if the NEO det engine has a front plate, im sure it would to protect the front of the timing belt or something. Water pumps...the pump I got was an NPW (yes grill me if I should've got a genuine one lol). It has a smooth mating surface, kit came with a pretty pathetic looking paper gasket. Do I need to use any RTV or just trust the gasket will work because its a smooth mating surface? Cheers legends have a good Easter break!
    • Cheers man, I thought the same.   Bit of an update on it all. It was definitely blue smoke, not grey after all. It didn't really smell oily but it was blue after all. Also puffing just the smallest amount on idle with no throttle.   I ended up pulling the intake and exhaust off and there was around 3mm of axial play on the turbo shaft. So I figured we'll that's buggered and sent it off to get hi-flowed at hypergear. Haven't got it back yet.   I haven't compression tested it yet. Had a look in the cylinder and cylinder 1 spark plug, looked a bit sooty but not oily. Then I've just started doing my timing belt because it's age is unknown.
    • In that case it is probably stock. It lives in the navigator side footwell behind the plastic trim just in front of the a pillar.
