Hey,
I bought this plenum for my car when I was in the "i need parts" stage but now I need money to put the parts on my car and I need a car to drive so I am willing to sell it to get enough money to start finishing my car.
I got the plenum from NZ and it is the same as the ones in the pic below as the guy who owns that car designed/made them. There wre only ever five made. The car below has over 400bhp on 12psi so they must work well.
I have a NZ magazine with an article on the car below and the buyer can have that.
I wont part with it for anything under $500 so please no rediculouis offers.
The plenum isnt polished like the one in the pics below but can be done obviously. It takes the standard TB as well.
http://home.iprimus.com.au/neilorourke/plenum.jpg
http://home.iprimus.com.au/neilorourke/plenum2.jpg
http://home.iprimus.com.au/neilorourke/plenum3.jpg
Thanks
Evan
hey,
Mods to fit are: Addition of longer throttle cable, lenthn TPS wires, shift fuel pressure regulator from the side to the end of the plenum and weld up the old regulator hole. Bolt the cold start sensor to the mount on the plenum and run a flexi pipe from the stepper motor to before the throttle body.... Thats all
Evan
Is that the standard plenum modified for front facing ???
Looks nice - Can you send pic of your actual item for sale to [email protected]
Thanks,
Some **** stole my digital camera at my brothers 21st so I dont know how I could get a pic... I will have to borrow a camera...
I will give a quick rundown.... the same structure exactly... lug between barrel and stock item isnt sanded back flat on my one... i have started to sand back the cast area smooth so I can polish it. Will look the goods with minimal work.
Evan
Hey i'm SUPER interested in buying this... will u take $450?
If i decide to purchase i will have my bro pick it up in sydney ok
PM with details etc and we can move from there ok
    • Given it is temporary, I bought a  cheapy gauge mount (which has become enflattened) which I will screw into the existing phone mount Also a first for me; given this is a temporary install I could not think of any reason not to use one of those "add a fuse" thingies to source the battery and IGN power. I had always figured they were pretty dodgy but having a good look at them I think they are a valid option for sourcing power from an existing source without cutting
    • Finally for now, a bit more work on the transmission temp gauge. I was wondering how Raceworks do a gauge for $100 that autometer want $500 for. No idea about the accuracy of course, but they have cut a few corners that made things hard.  First one I mentioned above, the sender is physically difficult to fit and doesn't work with their own adapters (the extra fittings I used to get the sender into a hose cost more than the whole gauge, lucky I had stuff in the shed) Second, the temp sender wires are way too short. They are shown as 2.7m on the box and I know my routing was long from navigator headlight to driver's firewall back to centre console, but I had to lengthen them by about 2m total - 2 joins in each wire. Also, same with the supplied power loom, they needed about an extra 1m to get the fuse box where I sourced power. Another join in each wire since one end wasn't supplied terminated. I know they could argue that the wires might be long enough depending on situation, but when you consider parts and particularly labour, it would be a very expensive cheap gauge if you can't do the work yourself. And, only a small issue....but it would have been nice if they remembered to tap a tread onto *both* spacers they supplied for the bracket....I haven't had to use the M4 tap often!
    • If it does get a turbo it would blow the JCW Mini out of the water considering how "close" some of the tests were. Then again the Mini would probably get one of them Stage 69 tunes.
    • Next up, the extinguisher is mounted but really only temporary because I ran into clearance problems (the bracket fit fine....until I put an extinguisher on it). It picks up the seat bolt mounts but has long bolts running through 20mm spacers for now Doing it properly requires a bit of quick welding but I ran out of time, this will do for the practice day
    • Family events weekend but a snuck a couple of things in. NSW state champs were down at Wakefield so I got Gordon Leven's to bring some A052s down in the right size for some spare rims I had that "fit" (actually ex-Leaf Nismo.Rays in 18x7.5). Tyres are 235/45/18 so they are narrower than stock (19x8.5s) but I need to keep road tyres on it for daily use for now. In a first, those weird size tyres had been in the yoko warehouse for so long (4.5 years apparently) that they offered 4 for the price of 2....so 4 practice tyres for about $1100. Bit of a bargain for sticker tyres, considering the real purpose of the practice day is mostly to see how the various temps go (and the weather is due to help, forecast 32o). In terms of race wheels, it looks like I should be able to fit 9.5 fronts and 10.5 rears but 18 vs 19 height will be based on what tyres I can get in the right size - good tyres are very limited in available widths in diameters above 17" so some planning is needed. Once I'm sure this car will work I'll order a set of custom BC wheels like I did for the R32, you can get exactly the right width and offset to make the most of the available space in the wheel well (the 32 has 295s all round on 18x10s and they are awesome) Incidentally A052 are asymmetrical but not directional which is good news for rally use if the front and rear wheel sizes are different because I can swap them side to side on the same axle. Directional tyres are a nightmare with staggered size wheels because each tyre is fixed on that corner unless you can get it rotated on the rim (not really practical mid rally in most cases)
