Details as follows:
1990 R32 GTS-t Mspec
RB20 motor with 70,000ks
strong RB20 gearbox with C's short shift kit
TD-06 20g L2 turbo kit comes with lines manifold, 3" dump, external gate (just rebuilt with new gaskets and 1bar spring) with screamer fitted. (Full GReddy kit)
HYBRID GT FMIC with GReddy hotpipe
Just Jap oil cooler and relocation kit (brand new)
APEXI power intake (brand new)
NISMO dash
BRIDE Zeta III sport drivers seat (standard passengers seat)
2 way
TEIN shocks and springs
16" RAYS Syver rims with legal rubber
front and rear strut brace
Cyclops Alarm & GReddy TT
PLUS OTHERS
Just fitted: HKS 264 cams, Tomei 555's, Z32, GK Tech cam gears (new timing belt) Fresh MOTUL 300V chrono oil, fresh gearbox/diff oil, brand new fuel & oil filter.
Replaced all the exhaust manifold studs/bolts, i have a full set of (brand new) Trust gaskets for the turbo and a new manifold gasket as spares.
Car is all finished and ready for final tuning.
Offers around 14k ono or trade depending on said vehicle.
NOW WITH 6 MONTHS REGISTRATION
Cheers GMB
https://www.sau.com.au/forums/topic/255627-eoi-r32-gts-t/
  • 4 months later...
looks tidy. Any idea what she's got at the wheels?
As it hasn't been tuned yet and only driven off boost i cant say but it should push 250ish at the wheels pretty comfortably.
Once tuned will put it on the dyno to check :)
Cheers Ben
https://www.sau.com.au/forums/topic/255627-eoi-r32-gts-t/#findComment-4708369
  • 1 month later...
swap for my 32? You want a standard one, and I want a modified one :)
I dont want a standard one, im putting it back to standard so its hopefully easier to sell.
I have everything you need to modify yours though :D
https://www.sau.com.au/forums/topic/255627-eoi-r32-gts-t/#findComment-4762083
    • Sorry no - The sandtrap adventure ended the day, happened at the end of the last session. At that time I wasn't hearing any weird noises nor were the brakes shuddering anymore. It was only when watching the videos that I remembered I had these sounds early on!
    • Did the noise appear after your sand trap adventure? Could be something got dislodged and is playing rub rub. Even a rock wedged somewhere.
    • Is there a shroud around the tailshaft spline into the back of the box? They can rub and make a horrible noise if they are not on straight/damaged. The heat might have caused it to grow too much in one direction and rub.
    • Strangely I noticed it either disappear later in the day, or not be present. I definitely noticed when I was crawling around that open wheel thingy entering the pits (that part was audible in car). Driving home and commuting around town for example, I didn't hear it. It's plausible that it was a brake disc or something still slightly in contact. The brakes absolutely felt BAD for the first couple of sessions, huge amounts of shudder and grinding as they got up to temp - And then I actually just forgot about it as the day went on/didn't notice it. The videos were from the morning when this was more present than the afternoon/drive home when it wasn't. I've asked around and got a variety of responses including handbrake shoe contacting hub, CV joints, CB tailshaft bearing as above, and clutch input bearing. I didn't test if it disappeared when clutch was in. I haven't noticed it in any of the other videos nor did I notice it when driving to that extent. More or less hoping the microphone at the rear license plate giving some kind of clue of 'something' but it looks like "spin stuff and see if you can notice it" is the way forward here. I could be smart and use the gopro mic and re-mount it to that location to see if the sound is still present at low speed actually. Sounds like a decent test whenver I have the CBF'ness to drive the car again. Given it's almost 40C for the day of the track day and the next 3 days after, the CBF is high. All I've done since getting home is unpack the car, remove the remnants of the lip and undertray and left it there. I was surprised how well the PMU Club Racers actually worked. The brake performance on the track was absolutely fantastic, best I've ever personally used, no fade whatsoever and the bitiness was almost too good, I was scrubbing more speed off than I needed to, but I also ended up infield when I started trying to scrape off ... less speed.... so...
    • Not really, no. Anything you would do is easily reversible.
