Because the wheel base is the same, i don't think there's any difference between the two, but i'm not 100% sure on that. Is your car already turbo? I think all you should need is a turbo manual tail shaft. I think the only difference is from turbo to n/a and auto to manual but not from 2 door to 4 door, but i could be wrong.
Having said that, personally, i would still make sure i had a 2 door and a 4 door tail shaft when it came time to do the conversion.
Some one else may be able to provide some more insight. :happy:
  • 2 years later...
where would i find this info as i just bought a 2 door tailshaft. the only difference i no of is yes between auto and manual and the 4 doors have different boot lights and rear bar and the 4 door is only 50mm longer than the 2 door. if anyone can concrete confirm this it would be greatly appreciated.
you will need to modify the gearbox bracket. The 4 bolt holes that are in the body for the bracket are further forward in an auto, the hole in the floor is also in a different position but thats ok.
what will happen is regardless if you use an auto/manual bracket (they are the same anyway) you will go to bolt up the bracket and only one hole on each side will line up, you will need to either modify the bracket like I did to make it longer and drill 2 new holes for the other two bolts..
OR
get two flat steel bar peices and bolt them to the underside of the bracket, recess the head of one of the bolts into the chassis and drill a hole at the other end of the bar to mount into the body.
you will then need to bridge the neutral park switch circuit so it thinks its in park all the time, otherwise it wont start
OR
cheers for the reply mate. couple of questions
1. if you say the holes in the floor are further forward in an auto that would make them 2 different chassis auto/manual correct? as you said only 2 of the holes line up so is this with the gear box mount connected to the steel plate that bolts to the floor? is there anywhere on here that has a diagram of where to bridge the neutral switch?
thanks.
that is correct.. if you look under your car the 4 holes in the floor are actually a metal panel that has been spot welded around the tunnel. They positioned this peice in one spot for auto and one spot for manual. So yes the bodys are different, but this is the only difference. Auto/Manual tailshafts appeared to be the same length too.
I did find a thread on here on where to bridge it, its a peice of piss. Where the fuse box is in the engine bay there are some grey plugs on top of eachother. I really cant remember which one you do, but basically you splice into one of the wires on one of those grey plugs and you bridge it into another one of the plugs there.. Search and you will find, thats how I worked out what to do
    • Well, in the same way that you can't tell any SUV from any manufacturer in any size category from any other one, "sports" coupes now all look identical. Stand back and squint your eyes and the Supra and the 400Z and the GR/BRZ things all look the same. I was just thinking last night, when sitting behind a Subaru CrossTrek, that I have no idea what it is, how it differs from an XV, or a Forester, or an Outback, or anything else Subaru offer, and I couldn't tell if it was supposed to be small, medium or large. I contrasted that to the good old days, where a HQ Kingswood had familial similarities to an LJ Torana, but there is no way that you could confuse them, and how a bit later, the HX Kinger and the concurrent Torana and the Gemini all had familial similarities, but you still could not confuse them. Ditto the ugly Fords and Chryslers of the era. But now, a RAV4 looks like a Kluger, looks like a Yaris/Cross/whatever they're calling those stupid f**king things, looks like every other Toyota that's not a Camry/Corolla sedan.
    • The Prelude doesn't look that bad without all that lens distortion in those pics. Makes it look disproportionate when it isn't. Actually I kind of liked it at the Osaka Auto Messe earlier this year.
    • Pour in the highest octane, non-ethanol fuel you can get and see if the readout changes. If it's dead bang on 11% then I would question the sensor. Another quick test, just take it out and run normal (in an american accent) gas-o-line through it and see if the sampled ethanol or lack of changes.   United E85 here in the land of drop bears does vary a bit, I've had as high as E87 (could be water in their tanks too, who knows)
    • Yep. And if you ever do, you'll just have to deal with it then.
    • E10 is pretty tightly regulated in percentage. Too much and engines can't adapt. Every incentive is against them to have too little ethanol though. The more ethanol the higher the octane.
