Have a rb25det neo and have purched Tomei Poncams 260degree 9,15mm lift.
And Tomei valve springs type B with Retainers for the intake side why not for the exhaust side aswell??
And do I have to shims the lifters if so How do I do? Any pics?
What is the part number for the springs you have purchased?
Do you have the equipment to change the springs and is the head on the block or off it?
163022 is the part number
Yes I have stuff to shange the springs the head is off.
Edited by Mikael Jansson
I'm pretty sure that number suits R33 RB25DET, Not Neo.
Correct me if I'm wrong.
Also I don't think springs are required for a 9.15mm lift upgrade on a Neo either.
The springs suits rb25det with solid lifers and I have that stock on my neo so I think it will fitt??
OK but how do I now if I have to shims or not?
These springs will NOT suit your application, they are designed by tomei to work with the solid lifter conversion for an r33 RB25DET not a neo, and honestly your better off spending your money on a set on i think its performance valve springs.. much cheaper and work just as well if not better, the yen is shit and anything from japan is stupidly expensive at the moment.
Exactly what Cartman said.
These springs are for the 33 RB25DET with solid lifter conversion. They do not suit Neo.
What part number did you get for the camshafts?
i had a solid conversion kit and it included the same springs with only one side of retainers.
You should stay with the hydraulic lifters and save the hassle.
its a neo you dingis . how can he stay with hydraulic lifters if he never had them in the first place?
  • Like 1
    • Use a 2' length of hose (that's 2 foot, not 2 inches) as a stethoscope to localise the source of the ticking. From cam covers? From exhaust or turbo manifold gasket? From injectors? From lower down in the engine? Etc. Use a timing light to set the timing. Put Redline Lightweight Shockproof in the box. It's not the very best thing for the box, but it will take a box that refuses to engage a gear with other oil, and make it engage a gear. I had to put it in when I installed the R33 box I have in my car. It would not select ANY gear when running. Smurf jizz made it work. That was >10 years ago and I still use it. I'm stuck with it now. Failing that - rebuild the box.
    • Well done Duncan. The fuel tank bulkhead lid is also in great condition (some of mine were stuffed). These are now out of production and good ones like that are becoming hard to come by.
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
    • Howdy all,   I had my rb25det S2 rebuilt and finally started it today but have run into a few issues  Engine sounds like a a diesel easiest way to summarise like small ticking, gets louder when revs are slightly adjusted  The engine builder repainted the engine cover leaving no where for me to go off with lining up the CAS so have it as central as possible so not sure it that could be affecting it?, changed the gearbox fluid too but won’t seem to go into gear when running, and only 1 to 4 when off having a hard time finding 5th and reverse anyone got any ideas or a base for me to start off? much appreciated
