Hey Guys
Just wondering what the going rate is these days to get a r33 gts-t engine built to handle 400rwkw, i want it to be a strong engine, not an engine i will just boost up for the 1/4 mile. As i am in melbourne which turbo mechanics would be best to go too?. I want to spend about $9,000 tops on the engine internals to achive 400rwkw, do you guys think this is posible on this budget?
What type of modifications can i aspect for $9,000?. The turbo is not included in the $9,000 as that will be purchased in the near future.
Cheers Guys for your help
Shaun
Let us know how far you get with $9k. I've learnt that yes you may spend 9k on the engine but your going to spend about the same or less on suspension, diff, computer and so on. I would get expert advise before i went ahead and built a 400rwkw bottom end. Pm Sydneykid as he knows alot about this sort of work.
Good luck
Harun
Hi Shaun, I really need to know a few things before I can comment;
What have you already done to the car?
What is your horsepower target?
What are you going to use the car for?
What work can you do yourself?
What is your budget?
Be realisitic in your answers and I will try and give you reasonable suggestions to suite.
Hey thanks guys for the replys,
Hi Sydneykid, ok so far i have a stock as a rock R33 Gts-t, things like exhaust sysytem are no dramas as my mate works at an exhaust shop. Horsepower target hopefully will be around 600Hp, (447rwkw i think). The Budget i intend to spen on "JUST" the engine alone is $8,000 - $9,000, i have a totally different budget for other engine parts. So The Engine has to be built to handle 600Hp for $9,000 is this possible?. The intend use for this car will be a bit of every thing 1/4 mile, daily driver and drift car:D. I will be able to do some things myself but other thAn that i can get it done threw my mates or if worst comes to worst, threw a turbo workshop. So Rember ($9,000) to Spend on engine internals, cams, rods, pistons ect ect all the stuff to make a stable and slightly worked rb25det engine.
Thanks for the help guys
Shaun
PS: I want to build me car around the JMS R33, but without stock internals:p. Turbo i will be using is a Garrett GT 3540.
Firstly you said bottom end, then referred to cams etc, so i take it you mean engine internals.
A budget of $9000 will probably get you the pistons, rods, cams, valvegear, but my concern would be that at those sorts of power figures, what is a realistic km expactancy for an engine with so much hp/Litre. 160kw/L at the wheels is a lot of power.
If driven as you would expect such an engine to be driven, is it reasonable to presume every 10,000-15,000kms that the engine should stripped and inspected... afterall it is a hell of a $$$$ investment.
YEah - I don't think you will get 447rwkw out of the Rb25 without doing somehting radical like stroking it and putting a huge turbo on...
But if you do - I wanna see that !
Good luck dude ! :(
Hi Shaun, we have a 3.1 litre engine on the engine stand, it has;
JE forged Pistons
Total Seal gapless rings
Carillo forged conrods
ARP rod bolts, head and main studs
Balanced and linished crank
9 to 1 compression ratio
O'ringed block
HKS exhaust manifold
Garrett GT3040
Clevite bearings
N1 GTR oil pump
N1 GTR water pump
Winged and baffled sump
RB26 head, throttle bodies and plenum
Head is ported and both manifolds are matched
(it flows 645 bhp on the flow bench at 2 bar vacuum)
Iskendarian valve springs
Titanium retainers
Tomei head gasket
Jun adjustable cam pulleys
Standard R32 GTR camshafts
I haven't run this one on the engine dyno yet, but it's sister (there are 5 in this batch) made 625 bhp at 7,250 rpm using Elf LMS. With upgraded camshafts and a GT35R, 700 bhp would be easily achievable. As for durability, the sister engine has completed a full season of racing (circuit and drags) and 6,000 k's of road work. It's leak down test is within 3% of when it was new, so another season is on the cards.
Does this sound like something you would be interested in duplicating? Depending on how much work you can do yourself and how many of the above parts are outside you requirements $9K should be doable.
Tick off the bits you need and I can tell you how much they will cost.
Hi guys, assembling the bottom end of an engine, bolting on the head and setting up tjhe camshafts is best left to someone who has the experience and the equipement. But that is less than 50% of the time it takes to assemble a complete engine. With a limited number of tools and experience many people can do the other 50%. Stuff like bolt on the oil pump, sump, water pump, cam tensioner and idler, flywheel. engine mounts, air con compressor, oil filter, turbo oil and water fittings, power steering pump, cambelt covers, coils, etc etc.
Saves money if you have the experience and tools.
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
    • How complicated is PID boost control? To me it really doesn't seem that difficult. I'm not disputing the core assertion (specialization can be better than general purpose solutions), I'm just saying we're 30+ years removed from the days when transistor budgets were in the thousands and we had to hem and haw about whether there's enough ECC DRAM or enough clock cycles or the interrupt handler can respond fast enough to handle another task. I really struggle to see how a Greddy Profec or an HKS EVC7 or whatever else is somehow a far superior solution to what you get in a Haltech Nexus/Elite ECU. I don't see OEMs spending time on dedicated boost control modules in any car I've ever touched. Is there value to separating out a motor controller or engine controller vs an infotainment module? Of course, those are two completely different tasks with highly divergent requirements. The reason why I cite data sheets, service manuals, etc is because as you have clearly suggested I don't know what I'm doing, can't learn how to do anything correctly, and have never actually done anything myself. So when I do offer advice to people I like to use sources that are not just based off of taking my word for it and can be independently verified by others so it's not just my misinterpretation of a primary source.
    • That's awesome, well done! Love all these older Datsun / Nissans so rare now
    • As I said, there's trade offs to jamming EVERYTHING in. Timing, resources etc, being the huge ones. Calling out the factory ECU has nothing to do with it, as it doesn't do any form of fancy boost control. It's all open loop boost control. You mention the Haltech Nexus, that's effectively two separate devices jammed into one box. What you quote about it, is proof for that. So now you've lost flexibility as a product too...   A product designed to do one thing really well, will always beat other products doing multiple things. Also, I wouldn't knock COTS stuff, you'd be surprised how many things are using it, that you're probably totally in love with As for the SpaceX comment that we're working directly with them, it's about the type of stuff we're doing. We're doing design work, and breaking world firsts. If you can't understand that I have real world hands on experience, including in very modern tech, and actually understand this stuff, then to avoid useless debates where you just won't accept fact and experience, from here on, it seems you'd be be happy I (and possibly anyone with knowledge really) not reply to your questions, or input, no matter how much help you could be given to help you, or let you learn. It seems you're happy reading your data sheets, factory service manuals, and only want people to reinforce your thoughts and points of view.
    • I don't really understand because clearly it's possible. The factory ECU is running on like a 4 MHz 16-bit processor. Modern GDI ECUs have like 200 MHz superscalar cores with floating point units too. The Haltech Nexus has two 240 MHz CPU cores. The Elite 2500 is a single 80 MHz core. Surely 20x the compute means adding some PID boost control logic isn't that complicated. I'm not saying clock speed is everything, but the requirements to add boost control to a port injection 6 cylinder ECU are really not that difficult. More I/O, more interrupt handlers, more working memory, etc isn't that crazy to figure out. SpaceX if anything shows just how far you can get arguably doing things the "wrong" way, ie x86 COTS running C++ on Linux. That is about as far away from the "correct" architecture as it gets for a real time system, but it works anyways.
