that's very good but i can't afford a S2 i don't think... haha
plus i HAVE sat in one and was VERY impressed
until the dude at (not naming names) said i can't aquire a V35 ANYWHERE for under 40K i was like
ohrly?
mate I am in Perth and a call like that about not getting one under $40K is rubbish. I got private sale 2 weeks ago a white coupe, 16000 kms (i believe genuine, not one sign of wear anywhere and still smell the leather), manual, series 2, premium, sunroof and optional 19" rims and that was a lot closer to $30k than $40k.
have a look around locally at private sales, its buyers market.
happy to take you for a spin too if you are interested in anything since you are a local fella.
On the topic of V35s do they have cruise control?
nope. the american g35's did (maybe premium only, but regardless, very common) but v35's didnt apart from the very rare speed-sensing cruise control but i think that was sedan only.
not factory. I do a kit for them that you could pass as factory though. uses the OE controls on the wheel.
what happened to you rowan
it was sposed to be ceffys for life
now you're deciding for a coupe
noooo....who ever gets your ceff, better keep it in good condition or ima have to hunt them down and take it from them hahaha
mmm unless someone else is out driving my car then yeah i was haha but as far as im aware i was at my gf's the whole weekend haha
yeah new cars are nicer and you dont usually have to worry bout them falling apart or trying to source much needed unavailable parts
ive been looking at jzx100 chasers of late, but yeah cant wait to see what you get
    • GTSBoy on your suggestion on another thread I had a look at those injectors and ended up getting them because of the quality.  Got the expensive ones.
    • Hey guys been looking everywhere to try and find the correct gtr hood latch support part number but only found the first half and when I search with that number it sends me to an r34. The first part I found was 62515. If anyone could help me with the rest then I’d really appreciate it. Or if there’s some alternative hood latch support that would work even better cause I can’t find any for sale. (Searched on upgarage, partsouq,buyee,rhdjapan)
    • If you've only done the upper control arms on the rear, AND you have changed their length (by more than about 1mm) to set the camber you want, then you will definitely need/want to install traction arms also. Adjusting the camber arms on their own WILL introduce bump steer and make the car unpleasant to drive. Most owners have no idea that their car could behave infinitely better than what they put up with. I'm not entirely sure what the Stageas need, but I am thinking that unless you have massive front spring rates and pretty soft rear springs, you have waaaay too much rear bar. Oversteer city, in my estimation. Combined with possible excessive bump steer from maladjusted arms, that could be a recipe for nastiness. ATR43SS2 is not a highflow. It is an outright replacement turbo. It's a little bit bigger than the largest highflow profile that Tao does. Probably a solid 300rwkW turbo where the bigger highflows will be about 30-40rwkW less. Nevertheless, we're only talking about ~300 rwkW, which is well within the abilities of the stock ECu to run with a Nistune on board. I would do so without hesitation - and I will be doing so when I get my finger out and actually get the injectors and AFM installed. But, if you would prefer to drop a whole lot more money on the ECU side, then I suspect you're looking at Haltech. The Haltech fanbois here will all spout on about all the available engine protection you can have, that you can't have with the Nistune option. And they're right. But it doesn't really come for free either. You will spend more money on extra sensors and the like, plus the work to install them. If the engine was built and therefore represented a big investment to protect, then I'd say definitely do it. If you view the current (and forever into the future) shortage of replacement engines as something to prompt similar protection, then also, do it. If you see a destroyed RB25 as an opportunity to put in a Mercedes or other V12 (like I kinda do)... then your perception of the risk/reward might differ. These are good injectors. You can also get a "better" set of the same with more flow matching, for more $$. 1000cc is where you will want to be. You will need an R35 AFM and adapter tube if you want to stay with Nistuned stock ECU. Otherwise, if going Haltech, you can ignore. As for intercooler. Just about anything will do. You're only talking about ~300rwkW. Just put a big core in there. Be aware that return flows do add significant pressure drop and will cost power and will make the turbo work harder to achieve the same goals. If you can manage a proper crossflow, do it. I'm keeping my very good return flow because I'm only expecting to be in the ~250rwkW range, and will live with whatever outcome I get.
    • I have a heap that i have collected if you want some authentic ones still. Pm me if your interested!
