Stupid Arse Simple Question
that's very good but i can't afford a S2 i don't think... haha
plus i HAVE sat in one and was VERY impressed
until the dude at (not naming names) said i can't aquire a V35 ANYWHERE for under 40K i was like
ohrly?
mate I am in Perth and a call like that about not getting one under $40K is rubbish. I got private sale 2 weeks ago a white coupe, 16000 kms (i believe genuine, not one sign of wear anywhere and still smell the leather), manual, series 2, premium, sunroof and optional 19" rims and that was a lot closer to $30k than $40k.
have a look around locally at private sales, its buyers market.
happy to take you for a spin too if you are interested in anything since you are a local fella.
On the topic of V35s do they have cruise control?
nope. the american g35's did (maybe premium only, but regardless, very common) but v35's didnt apart from the very rare speed-sensing cruise control but i think that was sedan only.
what happened to you rowan
it was sposed to be ceffys for life
now you're deciding for a coupe
noooo....who ever gets your ceff, better keep it in good condition or ima have to hunt them down and take it from them hahaha
mmm unless someone else is out driving my car then yeah i was haha but as far as im aware i was at my gf's the whole weekend haha
yeah new cars are nicer and you dont usually have to worry bout them falling apart or trying to source much needed unavailable parts
ive been looking at jzx100 chasers of late, but yeah cant wait to see what you get
 Share
    • Much less twat-tastic. CF wheels are too garish for civilised use.
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
