  • Replies 47
Posted Images
Could be anything really.
I would assume the red light is for your alarm when you arm it it blinks to tell you its on...
The siliver flick switch, Im guessing a RWD/AWD or 4WD switch..? Could be some activation switch for flog lights...
Can you pull down the compartment lid that its stored in and trace the wires and connections..?
https://www.sau.com.au/forums/topic/255712-mystery-switch/#findComment-4409863
try it and see?
maybe it's a simpsons style switch for 'MERRY CHRISTMAS 1984' on your roof?
Lol I tried it and it doesn't actually seem to do much when the car is stationary. Not really game enough to fiddle with it during driving, in case it kills power or locks the steering or something bizarre.
https://www.sau.com.au/forums/topic/255712-mystery-switch/#findComment-4409864
Lol flog lights. The compartment lid is for the moneybox... can't see wires in it. I checked and you're right about the red light.
It would be awesome if I had a 2WD/AWD switch there without knowing it.... Wax On, Wax Off, Drift On, Drift Off.
https://www.sau.com.au/forums/topic/255712-mystery-switch/#findComment-4409875
Doh! FOG lights I mean. LOL!
Maybe switch on the car and let it idle, then flick the silver switch and see if any lights pop up in the dash / cluster were your speedo and tachos are... Also hear out for any noises when the swtich is flicked...
Or take it hard around a corner then pull over, let it idle for a minute or 2, then flick the switch and take it hard around the same corner to see if it makes any difference...
My friend Tim GTR on SAU has a R33 GTR with a flick swtich and its for the 2WD/AWD switch and when you activate it, there is a a quick "Humming" or a very low tone "Beep" "Beep" noise.
But thats just his car.
https://www.sau.com.au/forums/topic/255712-mystery-switch/#findComment-4409905
No sounds or icons light up when idling and flicking back on forth with the switch. I might try the cornering thing when it's raining, just to make sure :)
So I guess the other R34 GTR owners don't have this switch? Maybe it's just a dummy switch installed for looks lol.
https://www.sau.com.au/forums/topic/255712-mystery-switch/#findComment-4409938
Could be a "Cheat" switch LOL!
Friend imported a R32 GTR and had this switch and when you flick it, it activates the brake lights, so when ppl are street or circut racing you and see you brake light flickering, they slow down, but you still keep going LMAO!
https://www.sau.com.au/forums/topic/255712-mystery-switch/#findComment-4409950
My Money is on Neons :)
ROFL.
Wow, that is such a dastardly evil invention! Would be great for those tailgating douchebags as well. I checked though - unfortunately it's not.
https://www.sau.com.au/forums/topic/255712-mystery-switch/#findComment-4409971
I wouldnt think it would be to turn off the immobiliser/disable... that would be a bit pointless having it in full view
It wont be a 4WD/RWD switch, you cant run a 34 in RWD without taking out the drive shaft (or you'll kill the transfer case)...
Stick your beaver under one or other side of the car and see if you can see something... cause im thinking neons too :happy:
https://www.sau.com.au/forums/topic/255712-mystery-switch/#findComment-4410105
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
