hey pplz
finally decided to sell my pride and joy s13 silvia
i picked her up as a shell with rego and compliance , unpainted and a few dents and scratches .
so we decided to clean her all up and give her a fresh coat of 2pac oranage/red , and slap a vertex big mouth kit on her .
Engine:
1991 s13 silvia
*ca18det motor with 73k on the clock
* ported and polished head .
*thicker tomei headgasket
*gates racing timing belt .
*tomei expreme exhaust manifold.
*garrett gt2871r .86 rear housing
*x force full 3inch turbo back exhaust system , with blitz canon
* custom cold air intake which runs to the front of the car near the cooler
* saber drift intercooler kit
*saber pod filter
*turbosmart fpr with gage
*440cc larger injectors
*2x after market thermo fans controlled by switch
*2ltr custom made oil catch can full with braided lines
*microtech lt10s stand alone computer
*walbro 500hp fuel pump
*ngk iridium tip spark plugs
*turbosmart megasonic blow off valve
*greddy (grex) 19row oil cooler with braided lines .
*dual stage boost controller
*saber boost gauge
*saber air/fuel ratio gauge
*saber water and oil temp gauge
* exedy heavy duty button clutch with lightened flywheel
*full genuine vertex kit
*flared rear gaurds
*nismo seat covers front and rear
* aluminuim overflow tank
* new vacuum lines
*drift handbreak
*razo electronic turbo timer
* Z tune style aftermarket bonnet
*toms steering wheel
Exhaust:
3 inch xforce turbo back exhaust with blitz canon
Suspension:
*hsd HR coilovers front and rear with camber tops and rebound adjustments
* whiteline front sway bar
*whiteline rear sway bar
*uras pinnapples
* whiteline front strut brace
*whiteline rear strut brace
*kazama castor rods
*steering wheel spacer.
*tierod end spacers 4 extra lock
Wheels:
*apec 17inch
*30mm uras hubcentric spacer
*235/45/17's all round
Stereo Audio / Visual:
* pioneer headunit
* fusion 6inch component speakers x4
* fusion tweeters x4
*clarion 12inch sub x2 boxed in the rear
*clarion monoblock amp
Estimated Power:
206rwkw on 18psi
PRICE $12,500 ono PRICE DROP $11,900ONO
car has been serviced religiously every 3000ks with royal purple
gearbox and diff also serviced every 5000ks with motul oils
PLEASE FORGIVE THE DIRTY INTERIOR PICS .
THE CAR HAS BEEN FRESHLY PAINTED (2pac) AND STILL NEEDS ITS FINAL BUFF CUT AND POLISH TO REALLY MAKE THE PAINT STAND OUT FURTHER
HERES A SHORT WALKAROUND CLIP OF IT http://au.youtube.com/watch?v=26N9IwwyXAo
also lookin a yamaha yzf r1 05 model and above
other swaps considered to
Edited by arabian_drifter
https://www.sau.com.au/forums/topic/255719-price-drop-nissan-silvia-206rwkw/
ill swap u my 84 ae71 CAna corolla with a locked diff n bucket seat 8 months rego no rust. fresh primer n flared guards, fully sick coustom built drift handbreak pollished alloy. 15x8 simmons. and a surf board.
pretty good deal
pretty good deal
yea sounds good
to good to be true
a straight swap would be like robbin you though , thats y im forced to give it a miss
