I know the GT-R isnt a 1/4 mile queen BUT - those following the launch control saga with the Nissan R35 may know that USA spec cars have had their launch control reprogrammed this week such that a) you CAN use launch control with VDC on and b) it will only launch at about 3000rpm now (vs 4800rpm or thereabouts before).
The expected results : it would blunt the performance right?
however it seems some guy has just set another stocker R35 record with the software update today.
http://www.gtrblog.com/index.php/200...-quarte?blog=4
11.34@120mph is pretty amazing given this is a 100% stock car.
I'm guessing the update involved a tad more than changing the launch rpm...
LSX-438....
The new launch control ran a 1.69 60ft on the Dunlops, its good, but not as quick as the 1.44 60ft generated on the old Launch Control ;)
Feeding in the clutches at 3000rpm with the traction control working isnt going to be as fast as sidestepping the pedal at 4500rpm which is what the old LC system did. Not many of these guys understood that unless they made the car 'hook' that axle tramp would destroy first gear....now its been made 'soft' there will be no such problems :)
LSX-438....
The new launch control ran a 1.69 60ft on the Dunlops, its good, but not as quick as the 1.44 60ft generated on the old Launch Control :)
hence my surprise Martin!
- especially at the 11.3 "stocker record"
personally i think it's quick enough, albeit with a 3000rpm launch.
Edited by LSX-438
Whats more surprising is the 11.6 from that same car 'dead stock' with no Launch Control at all :D
When I refer to 'hook' its hook-up off the line....
Edited by Martin Donnon
well that's true there could be something "special" going on with that car. Then again it's 3/10ths better from what we all expected (their prior results) - i think everyone just assumes it was going to be slower with the update, and yet it wasnt. I suppose we'll see a few others go out there soon and see what's what.
More results in...
Edmunds Update Their Long Term GT-R and Get Faster
Edmunds long term test blog has been debating on whether or not to update their Nissan GT-R with the latest software update from Nissan for a couple of weeks now.
They finally decided to go ahead with it (for science!) and have now put it to the test. They’ve confirmed what others are saying and the GT-R is only improved by this update.
Results - VDC Off:
* 0-60mph - 3.6 sec (3.3 adjusted)
* 0-400m ET - 11.6 sec @ 118.9 mph
Results - VDC On:
* 0-60mph - 3.6 sec (3.4 adjusted)
* 0-400m ET - 11.7 sec @ 118.5 mph
Their “tips” on launching the updated GT-R may explain why their time is not as fast as we’ve seen. Some owners are reporting that there’s more to it than just planting the brake and the throttle. There’s a certain technique and timing required to get the best out of the new launch.
They also don’t mention what transmission mode they’re in since you can now do it in manual and auto in any transmission mode.
Check out the link below for the full article with details and a comparison to their previous best results…
Link: Edmunds Blog: 2009 Nissan GT-R: Reprogrammed, Our GT-R Gets Quicker
