engine reconditioning is the trade of rebuilding an engine they strip the engine replace all worn parts like pistons liners bearings machine all parts to a new or better then new spec so its giving the engine a new life basicly i have a few mates that have this qualification but the trade itself is no longer taught as of last year the apprentices doing it now are the last of their kind
Firstly, Ryan could you try using some punctuation? Its really hard to read without fullstops and commas.
Secondly, what a crap trade! I love pulling engines down, but I couldnt do it all the time! Much rather do a mechanics apprentiship (which I am) and do a bit of engine conditioning. Thanks for that though, I've always wondered what it meant.
Thats better! Haha.
I was at Malaga Auto Repairs, but my boss got rid of me for no real reason, so I'm starting at Jason Mazda very soon. But in the mean time I'm in down time at MITA :domokun:
I was going to be a heavy diesel mechanic but the foreman at my work experience place was an arsehole and my now ex-boss offered me an apprentiship so I took it. Congrats on qualifying though!
yeah its a hard road but its all worth it in the end hey.
My advice is stay on the ball, be as keen as you can and dont let f*#% heads like ur old boss get you down. take it in your stride and you will be a better tradie then all of them. its just getting through the crap pay at the start lol
basicly yeah but to have it reconditioned means a qualified engine reconditioner did the work a rebuild means a mechanic did the work. Not that either is better then the other just different people did the work. Unless people get their terms mixed up then there is no diff lol
    • To expand on this to help understanding... The bigger/longer the block is, the more it's going to work to sit on your far away high areas, and not touch the low stuff in the middle. When you throw the guide coat, and give it a quick go with a big block, guide coat will disappear in the high spots. If those high spots are in the correct position where the panel should be, stop sanding, and fill the low spots. However, using a small block, you "fall off" one of the high spots, and now your sanding the "side of the hill". Your little block would have been great for the stone chips, where you only use a very small amount of filler, so you're sanding and area let's say the size of a 5/10cent piece, with something that is 75*150. For the big panel, go bigger!   And now I'll go back to my "body work sucks, it takes too much patience, and I don't have it" PS, I thought your picture with coloured circles was an ultra sound... That's after my brain thought you were trying to make a dick and balls drawing...
    • Oh I probably didn't speak enough about the small sanding block for blocking large areas.  In the video about 3 minutes in, he talks about creating valleys in the panel. This is the issue with using a small sanding block for a large area, it's way too easy to create the valleys he is talking about. With a large block its much easier to create a nice flat surface.  Hard to explain but in practice you'll notice the difference straight away using the large block.
    • Yep I guessed as much. You'll find life much easier with a large block something like this -  https://wholesalepaint.com.au/products/dura-block-long-hook-loop-sanding-block-100-eva-rubber-af4437 This is a good demo video of something like this in use -    You have turned your small rock chip holes into large low spots. You'll need to fill and block these low spots.  It's always a little hard not seeing it in person, but yes I would go ahead and lay filler over the whole area. Have a good look at the video I linked, it's a very good example of all the things you're doing. They went to bare metal, they are using guide coat, they are doing a skim coat with the filler and blocking it back. If what you're doing doesn't look like what they are doing, that's a big hint for you
    • The odometer does go up when driving.  Does this tell it is an issue with the speedometer itself?    Where can I look for replacement cluster? Or speedo? I can likely do the repair.. Will ER34 cluster work on HR34? Or do I need a HR34 20GT S2 specifically lol
    • Mine's a bit bigger at 70x150mm roughly. The spots are flat, just can feel the edges if I dig my nail into it. I did fix some other other ones by both using my finger to sand that small spot (I'm a bit wary of doing this and creating hot spots and a bigger mess) and I also did sand over it flat and others, but this also worried me a bit because if I create an overall low spot on the panel on paint that is good.  Correct me if I'm wrong but as long as it's flat even if I can feel the edges, I can put filler because it will all be level once I sand it? I can see myself going in a circle after sanding guidecoat with 320 grit if for example the panel is flat with my hand but because I sanded the guidecoat I could have created a low spot again somewhere. Unless where I'm going wrong is what I mentioned previously where I didn't go low enough on the grits. It's 1 step forward and 2 step backwards here haha. I'll probably need to experiment with it more. Last time I go back to bare metal lol.
