The BCNR33 4door Autech version was released as a 40th anniversary model of the Skyline GT-R.
It was developed by Autech Japan, a Nissan affiliate engaged in the development, production and sales of limited-edition vehicles.
To commemorate the 40th anniversary of the debut of the legendary Skyline this special model was built.
Some of these vehicles eventually found their way to Australia.
good luck finding someone who wants to part with one of these babies. Yes I do believe there are only a few in Aus, and I would think they would fetch a pretty price. I am currently trying to buy and comply a RS 260 Autech Stagea which Canberra is not making an easy task. Supposed to be allowed to comply Aug 03 now looking like Jan 04, bastards. Who has the compliance tags for the 4 door GTR or are they private Imports that have been brought in and re sold?
Cheers
Gary
Guest darrinspencer
if you see the white 33 gtr 4 door 4 sale (the one that was at capalaba, i live near there) beware.
I know the guy who imported it and repaired it. It had hit a pole dead centre in the front and the pole had fallen on the roof and crushed it. it has had a new roof and front put on it.
Do not get me wrong, the company that fixed it do a go job and i looked at the car about 2 days after it was finished and it looked pretty good.
I was told by the guy that did it, he said that were 100 made in japan, and you can buy all the parts to build your own. Mainly rear door skins and rear quater panels.
He also told me that a melbourne import company had a staright one arriving which would owe them about $100,000. this was about 12 months ago.
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
