Decent Rb26 Low Mount Ex. Manifolds & Dump Pipes
Hey Guys,
I'm after a decent set of exhaust manifolds and dump pipes to fit the stock turbos (or GT2860R-5s in this case).
The likes of Tomei, Expreme etc should be what I'm after.
Please PM me if you have some for sale.. the motor will be assembled fairly soon so I will need these asap :banana:
Thanks!
Stock manifolds ceramic coated are a VERY good option to go for, they'll never crack and fit the car perfectly. Also wont cost you another $1000 (at least).
If you must have a brand name, and in a rush, the options are;
-Tomei Expreme from Nengun or forum traders (who will probably have stock of them)
-Ring Kyle at 6boost and send cash straight away as they take time to make
Another option is to ring around the workshops that do GTR's and ask what they've got, you'd be suprised what workshops have in back rooms etc :domokun:
Id try RacePace first, then RECustoms etc
Hope that helps :P
    • You see R34 GTRs listed for 200-300k are they really selling for these prices? Kinda seems like the same ones listed all the time.
    • Only needed to pull out the seats, center console and gear shifter surround, took a weekend and a fair few beers. You get to look forward to finding all sorts of weird shit under the seats and carpet, I pulled out a Chinese dudes passport from 2003, 220 yen and a condom wrapper 😆
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
