Howdy,
Just posting to see if anyone is seriously interested in saving themselvers $$$ and getting heaps more power from their R32 and R33 Skyline GTST's???
I have for sale a brand spanking new GCG high Flow Stage II turbo still wrapped in plastic rated @ 500HP.
"The factory turbocharger is a ball bearing T3 sized unit with a ceramic turbine wheel. In upgrading this unit we replace the ball bearing pack with a new one while replacing the turbine wheel and compressor wheel with hi-flowed models."
Price is only $2000 where brand new they sell for $2450.
Condition is that you have to send me your old turbo or we can work something out personally.
oh and by the way.......I live in DARWIN :P)
Dude..
Please confirm with GCG that this turbo has a BALL BEARING center AND that it is OK on an RB20.
Last time I spoke with GCG in Sydney, the deal was that for just over $2K you give them your turbo and they rebuild it with Standard NON ball bearing center and replace the blades with T3/T4.
AND they have 2 options..
450 hp or the 500hp.
AND the 500hp was not suited for the RB20... something to do with surging due to mismatch or something..
On an rb25 they were both good.
But the main thing is the bearings.. If indeed they rebuilt it with BB center, then that is an awesome price..
However, I didn't think that ANYONE in Sydney had the Balancing tool required to REbuild BB centers.
GCG do have the nessacary tools to balance BB centre turbos, there is no problem using the 500HP turbo on the RB20..the surge they refer to is where the RB20 head runs out of effeciency and instaed of accepting more air from the turbo spits it back, this can be resolved with a port job and bigger cams. With having said that the 450HP turbo is better suited to the RB20 due to its smaller rear exhaust housing the turbo wouldnt be as laggy
watch high performance 4, they go into detail about this turbo upgrade. they use your existing turbo, replace both compressor and turbine wheels with t-04s specs + new bearing pack. and yes, they are ball bearing.
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
    • In true Gregging style...
