hey there, just wondering if anybody can help me out ?? i have a series 2 rs4. Once the car reaches operating temp on my way to work, the malfunction light comes on, i give it a rev and the light goes off and stays off, approx 45 km's to work. Very rarely does this happen on the way home in arvo.. nissan checked the code and told me most likely a coil fault. Since then i have fitted splitfires and new sparkplugs but still no difference. The car seems to be running fine and i can't notice any misfiring ?? any ideas would be much appreciated !! THANX
https://www.sau.com.au/forums/topic/255854-help-please/
check the codes yourself
this will show you which points to bridge
attached page will show you how to do it.
http://www.skylinesaustralia.com/forums/Ex...p;hl=paper+clip
Pages_from_R34_service_man.pdf
https://www.sau.com.au/forums/topic/255854-help-please/#findComment-4412411
I have access to Nissan Data Scan and live nearby. If you're interested we can plug it in & see what comes up after a datalog.
This sounds great BensDR30, can you explain how the data loggin works ?? i am only new to imports as i have spent my years on old skool v8's..
https://www.sau.com.au/forums/topic/255854-help-please/#findComment-4413171
hey there, thanx for the link, but i still couldn't see ne-where that explained how to do this in detail ??
https://www.sau.com.au/forums/topic/255854-help-please/#findComment-4413174
i had the same thing as you, check engine light flash up, give it a little rev and it would go away. when i checked the error codes it was the O2 sensor. but i would have thought nissan would have been able to give you a better idea of what it was when the checked the error codes. the error codes remain on the error code list until you reset them.
https://www.sau.com.au/forums/topic/255854-help-please/#findComment-4414720
Yeah, thats why i took it to nissan, but they admitted the had never worked on a stagea and didn't have any code lists to use as a reference... they somehow came up with a coil fault though ??? how would i change the 02 sensor ?? is there only one ??
https://www.sau.com.au/forums/topic/255854-help-please/#findComment-4414781
i wouldn't jump to the conclusion that it is the O2 sensor, i was just saying that i had the same thing with the light flashing up and going away with a rev.
i'd see if someone on here that lives close to you has the consult/datascan software can check you error codes for you, or do the error code thing yourself by bridging the two pins on the consult plug. or just go back to nissan and get them to check the codes.
see what the problem is before spending anymore money replacing parts that may not have anything to do with the problem.
https://www.sau.com.au/forums/topic/255854-help-please/#findComment-4414795
The O2 sensor is located just behind the turbo. It's not a big job, 22mm open-ender (or vise grips) to get the original one out. That bit can take a while, but fitting a new one is only a 5-minute job. There are threads detailing the replacement, but it's a pretty simple task.
https://www.sau.com.au/forums/topic/255854-help-please/#findComment-4414797
No worries, i have just read that nissan reccomends o2 sensors are replaced every 40,000km's anyway, so i will change the sensor and see how i go...
thanx heaps for the help guys, will post the result...
https://www.sau.com.au/forums/topic/255854-help-please/#findComment-4414943
    • Hi soviet_merlin, We appreciate your concern regarding this possibly being some sort of PR/Political hype, I assure you that is not the case, I wish we could claim something like that, but in this case, we merely reached out for comment on the basis of the outrage we too felt, as those heavily in the automotive industry. Ps. the original source in the social media post is CarExpert not CarExplore.    Best, CE.
    • Made a bit of a discovery, but while I was cruising, I randomly decided to test to see if it worked and it showed up on my IC7. The entire time I tested it before, I never thought to turn the ignition on. I only tested it with head lights turned on but with the ignition off. Huge oversight on my end. I’m a dummy. I know.
    • G'day all, I have drilled and tapped the hole for the relocation of the timing belt tensioner. That was straight forward. I'm unsure if I need to also put another hole for the smaller stud that the spring behind the tensioner catches on (this is how it seems to work in its original spot). Or do you not use the spring behind it and just torque it down? Thanks in advance, I did a search but couldn't find anything related and it doesn't mention it in the rb30det sau guide.
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
